I have built a scene that sets my 6 GU10 RGBW bulbs to blue. I then use an automation to trigger that scene when a button is pressed. When you press the button the lights all go blue as expected, then a second later most of them go white. Here is the scene:
- id: ‘1645826909547’
entities:
light.cinema:
min_mireds: 153
max_mireds: 500
supported_color_modes:
- brightness
- color_temp
- hs
- onoff
color_mode: hs
brightness: 255
hs_color:
- 240
- 100
rgb_color:
- 0
- 0
- 255
xy_color:
- 0.136
- 0.04
entity_id:
- light.cinema1
- light.cinema2
- light.cinema3
- light.cinema4
- light.cinema5
- light.cinema6
icon: mdi:lightbulb-group
friendly_name: Cinema
supported_features: 0
state: ‘on’
Here is tha animation. I have added a step to turn the lights off prior to calling the blue scene aboe. the reason I tried this is the lights are often white so I wanted to see if this helps, but it doesnt.
- id: ‘1646602942853’
alias: Cinema blue
description: ‘’
trigger:- platform: device
type: turned_on
device_id: 84834405c93ac9cb543c28a995a9f27a
entity_id: switch.cinema_switch_switch_1
domain: switch
condition: []
action: - scene: scene.cinema_off
- scene: scene.cinema_blue
- platform: device
Any hints as to what might be going on?
