Hello!
I have a small problem, that makes HA really anoying. I have a scene called “Turn On TV” that activates Broadlink transmitter and turns on TV and Tuner and scene “Turn Off TV” which does the exact opposite of course.
The thing is if I for example use scene “Turn On TV” and then I MANUALLY turn off tv or tuner, and the I use the scene “Turn On TV” again it won’t turn any of the mentioned devices, because it thinks it is already turned on.
Is there some way how to make HA trigger these switches everytime even though it seems for HA it had already been turned on?
I’ve tried changing assumed_state to false and it didn’t help.
Thank you so much in advanced.
SCENES.yaml
name: Turn on TV
entities:
switch.tuner_tv:
friendly_name: Tuner TV
assumed_state: false
state: 'on'
switch.bfs:
friendly_name: BFS
state: 'off'
switch.television:
friendly_name: Television
state: 'on'
icon: hass:television
- id: '1608641372738'
name: Turn off TV
entities:
switch.tuner_tv:
state: 'off'
switch.bfs:
friendly_name: BFS
state: 'on'
switch.television:
state: 'off'
SWITCH.yaml
switches:
- name: Television
command_on: JgAsAFobERsQDRANERsfDRANEA0RDBENEA0QDRANEQwRDBENEA0fDRAcEA0QAA0FAAAAAAAAAAAAAAAA
command_off: JgAsAFobERsQDRANERsfDRANEA0RDBENEA0QDRANEQwRDBENEA0fDRAcEA0QAA0FAAAAAAAAAAAAAAAA
- name: Tuner TV
command_on: JgBUAE0UExMnExQTJhMUEycTJxMTExQTExQTEycAA0tOExMTJxMTFCYUExMnEyYUExMUExMUExMmAANMTRQTEyYUExMnExQTJhMnExQTFBMTExMUJgANBQAAAAA=
command_off: JgBmAE4TJhQmFCUVExMmFCYUExQSFRIUJhQSFBMUExQSFBIAAsZNFCYUJRUlFRIUJhQlFRIUExQTFCUVEh
