I’ve moved my scenes into Node-Red as I find them easier to build than writing them out in yaml within Home Assistant. Over time, I’ve built quite a few scenes to the point where I’ve got that below. I’ve got switches and links to actual scene flows on different Node-Red tabs. Is there a better way to manage the switch to scene besides this method of adding additional entries into the switch (labeled Which Scene?)? I don’t see a way to add a lable to the link…maybe I’m missing something. If I keep adding more scenes, I’m going to the point where it is unmanageable in HA. Maye I’m already to the point. Right now, when I look at the switch, there’s not an easy way for me to determine which flow goes to which scene.
Appreciate any thoughts.
