My Home Assistant is on Home Assistant Cloud, Google Assistant is activated and 276 entities including scenes are exposed to Google Assistant, In Google Home I have linked Home Assistant Cloud by Nabu Casa. When I hit “Check for new devices” everything seams to work great, but I am not seeing any scenes in the available “devices”. I see my thermostats, plugs, lights and some sensors, but no scenes.
I have reloaded, I have restarted, I have tried overriding the UI by adding to the config (With no luck) and have unlinked and linked a couple of times. I am getting stuck here.
Voice commands don’t work at all (See attached). When i use google assist and type in “Master bedroom (light) light” it will turn on the light, but if i type in “master bedroom on” as you see in my alias, another light by the name “master bedroom (light over the bed) light” is turned on.
If i type in “scene off” (My alias for the scene “Master Bedroom (OFF)” I get “Sorry, I don’t understand”
It might be me not understanding what is up and down?
you say activate
you also can’t turn a scene off - must activate another scene
They are seem to no longer be listed - they were previously. You can see them under actions if you add an automation but they work as per above.
I am aware that I can’t activate and deactivate scenes. I trigger them and I have both an ON and an OFF for each of my scenes, for example, living room on and living room off.
After a lot of research and trial & error, i figured out devices are exposed and shown in devices in Google Home, and scenes are only shown when you add an action in a routine in Google Home.
So far, so good.
But even though I would add a trigger like “Kitchen Lights On”, it would not work … Instead Google Home would turn on a device called Kitchen Lights Zone 1 or something simular.
I then removed all devices from Expose to Google Assistant in HA so that I only had my scenes and now, since Google could no more match with a random device it works.
Note. Don’t use () in the names of devices or scenes exposed to Google, they will not show with the correct name.
