Hassio 0.100.3 working perfectly. Decided to take a snapshot and upgrade to 0.101.2 and the upgrade worked OK. Only problem is my scenes stopped working properly. The light comes on but the transition to 30% doesn’t work anymore.
I tried rewriting scenes etc. even considered not using them and adding the lines to the automations directly but that was a pain so I have gone back to 0.100.3 for now.
Any ideas?
This is an example of one of the scenes that doesn’t transition.
So aparently you cannot use the same service data attributes as in the ‘light’ domain anymore. I was very happy using both ‘brightness_pct’ and ‘transition’.
So where you were specifying states in the scene (like state: on for a particular light) in the script you have to specify services (like light.turn_on for the light you want on).
Not sure which version it started (0.100+ i think) but my scenes no longer work at all. So i thought (as i only really use two) i would just move to the new Scene Editor to keep things “native”.
However i can’t see most of my entities in the pick list. No switches at all! And only two lights showing!
Is there a limitation on the domains valid for the new editor? Any ideas why this scene would suddenly stop working:
I am relatively new to home assistant but have my place set up fairly well. I understand changes were made to the scenes editor implementation, but I also cannot use the editor anymore because only 6 “devices” are available in the device drop down : my phone, my Sonos speakers and my hone built esp8622 “devices”. None of my commercial lights and switches are available (lutron and some other wifi plugs etc)
However these entities/devices are available everywhere else (scripts, automations etc)
Basically scenes are now unusable and broken even if I try to use the editor as intended.
Have a look at the screen capture for new scene creation. I only have the option to add a device. Are you saying you have another drop down for entities ??
Al
Ok thanks for that. I tried on iwindows, iPad and iPhone and entities does not show up - bizarre ! Reinstalling HA and will see before and after I restore if I get the entities back
