I’m having trouble getting my scenes to activate with just some simple lights. I configure a scene in in the config file, and it shows up on the States page. When I click “Activate” to activate the scene, it does nothing, though I get the message on the GUI that the scene turned on. I thought maybe I needed an automation, so I threw together a quick automation. The trigger didn’t matter as I was going to trigger manually from the GUI…again…no joy. I’m not getting any errors when I restart HASS. Here’s the log entries form var/log/syslog when I try to activate the scene, and below that are the snippets from my configuration.yaml file. Any help would be appreciated. I’ve got an Alexa skill written and running, and now I want to get it to activate scenes for me.
Oct 21 02:44:55 raspberrypi hass[541]: INFO:homeassistant.components.http:Serving /api/services/homeassistant/turn_on to 192.168.1.1 (auth: True)
Oct 21 02:44:55 raspberrypi hass[541]: INFO:homeassistant.core:Bus:Handling <Event call_service[L]: service=turn_on, service_call_id=3051870160-23, service_data=entity_id=scene.testingstuff, domain=homeassistant>
Oct 21 02:44:55 raspberrypi hass[541]: INFO:homeassistant.core:Bus:Handling <Event call_service[L]: service=turn_on, service_call_id=3051870160-24, service_data=entity_id=['scene.testingstuff'], domain=scene>
Oct 21 02:44:55 raspberrypi hass[541]: INFO:homeassistant.core:Bus:Handling <Event service_executed[L]: service_call_id=3051870160-24>
Oct 21 02:44:55 raspberrypi hass[541]: INFO:homeassistant.core:Bus:Handling <Event service_executed[L]: service_call_id=3051870160-23>
automation:
- alias: Testing Scenes
initial_state: True
hide_entity: False
- platform: sun
event: sunset
service: scene.turn_on
entity_id: scene.testingstuff
# Scenes
scene:
- name: testingstuff
entites:
light.door:
state: on
transition: 1
xy_color: [0.6621,0.3023]
brightness: 255
