Scenes.yaml blank yet scenes exist and function
Same problem here !
I can see scenes that I once made, but I can’t find them onymore in the setup. And therefor, I can’t change the code or even delete the scene. It’s there but you can’t find / see it. You only can use it (how can it work when there is no code)
I found my problem… The scene I saw in the list of scenes in configuration, did not come from home assistant. The scene was retrieved from the connected integration (in my case Tahoma).
I can change this scene in Tahoma… and therefor it is not managed in home assistant.
Probably you have the same issue… check the connected integration for scenes / automations…
