myro
September 20, 2022, 8:13am
1
Hi everyone,
maybe I oversee something, but I’m not able to add events to the scheduler helper which are other than exactly 1 hour long: 30’ will be prolonged after saving while 1,5hour will get shortened.
Any idea what I do wrong here?
Kind regards
Klaus
tom_l
September 20, 2022, 8:26am
2
Nothing you did. It’s a bug with the way the card is displaying the schedule. If you initially set it for half an hour it will change state on and off at those times, it just won’t display the schedule properly at the moment.
opened 08:02PM - 31 Aug 22 UTC
### Checklist
- [X] I have updated to the latest available Home Assistant versi… on.
- [X] I have cleared the cache of my browser.
- [X] I have tried a different browser to see if it is related to my browser.
### Describe the issue you are experiencing
When editing a schedule helper, if it was originally set to end or start on half past the hour, when you return to edit the helper the UI is showing it running on whole hours not the original set half past the hour.
### Describe the behavior you expected
UI allows you to set by the half hour, this should be displayed as such when you reload it
### Steps to reproduce the issue
1: create a new schedule helper
2: set an "on" time for 21:00 to 21:30 (screen shot 1)
3: create the helper
...wait for the time to come around to check the scheduled end time...
4: at 21:05 checked the state of the helper and state is 'on' with attribute next event is 21:30
5: edit the helper the time is blocked out as 21:00 to 22:00 (screen shot 2)
6: save the helper
7: checking the attributes the next event is still 21:30
![image](https://user-images.githubusercontent.com/68328701/187769181-3252b9db-ddae-4d72-b205-21c86ad09f1b.png)
![image](https://user-images.githubusercontent.com/68328701/187771371-263ff4b0-0a89-4262-9d38-e1ec4f454db6.png)
### What version of Home Assistant Core has the issue?
2022.9.0b0
### What was the last working version of Home Assistant Core?
_No response_
### In which browser are you experiencing the issue with?
Google Chrome 104.0.5112.102, Edge 104.0.1293.70
### Which operating system are you using to run this browser?
W11
### State of relevant entities
_No response_
### Problem-relevant frontend configuration
_No response_
### Javascript errors shown in your browser console/inspector
_No response_
### Additional information
_No response_
