Schedule Helper is okay, but it could be so much better. If I may recommend the following changes.
- Rather than be in 30 minute blocks you should be able to adjust down to 1 minute.
- In the mobile app you can’t select 12 am.
- In the mobile app it is to hard to select or edit a schedule. If you could click on it with a pop up and then input the time rather than drag select.
- Should be able to go over a day so if you could click on it, pop up, then you could enter in time from say 10 pm to 8am.
Schedule is okay but it could be so much better with just some tweaking. I think it is worth the consideration.
Hope the HA Team read this and consider it.
Blacky
