I’m new on hassio and need some help to schedule a switch with google calendar.
All calendars are working because i can see changes from disabled to enabled on calendar entity every time I create an event on google calendar:
- cal_id: [email protected]
entities:
- device_id: xxxxx_gmail_com
ignore_availability: true
name: [email protected]
track: true
- device_id: test
track: true
I have created an automation with the calendar and the switch with this code:
- id: '1552340082272'
alias: Prova Test
- platform: state
entity_id: calendar.test
to: 'on'
service: switch.turn_on
entity_id: switch.llumtest
If I click to execute automation, it turns the switch on, but for an unknown reason the automation is not triggered by the calendar.test. If I change the trigger event with a time platform, automation is working correctly.
What I’m doing wrong?
Best Regards
