Hi
Only for a few days I have started playing with Home Assistant, I have previously used Domoticz, but HA gives a lot more possibilities.
I have several temperature sensors, I would like my automation script to send a pushover notification if the temperature in the garage drops below 0 degrees, and send a notification every 60 minutes until the temperature rises.
Unfortunately, my script does not work a request for help in automation
typ- alias: Temp min
platform: numeric_state
entity_id: sensor.sonoff_si7021_temperature
below: 4
- service: notify.pushover
message: "Temp below 4"
title: "Home Assistant"e or paste code here
unfortunately the configuration given does not work, the error code below
Invalid config for [binary_sensor.template]: expected dictionary for dictionary value @ data['sensors']. Got None
extra keys not allowed @ data['temp_min']. Got OrderedDict([('friendly_name', 'Temp below 4'), ('value_template', "{{ states('sensor.sonoff_si7021_temperature') | float < 4 }} ")]). (See ?, line ?). Please check the docs at https://home-assistant.io/integrations/template/
Invalid config for [notify.group]: invalid slug notify.pushover (try notify_pushover) for dictionary value @ data['services'][0]['service']. Got 'notify.pushover'. (See ?, line ?). Please check the docs at https://home-assistant.io/integrations/group/
