Same thing happend. At 03.00 the automation triggered and run. It does not update anything and the “update_list” is empty, only consists of “[]”.
Maybe I have a in-between version where you have removed some conditions for testing purpose. If I look in the blueprint for the part sending the mail, it looks like below, and will always run.
I just change to “all” and changed the schedule to now. The automation was running as expected, updating to 2023.1.1. No problems at all.
I changed the schedule again to trigger the above situation, and the automation did not fire.
The problem I have experienced earlier is in this specific scenario.
Automation is set to “patch” and there is a “major/minor” update waiting. If this is the case, then the automation fires, do NOT update (as expected), however still send the notification mails. So, this problem is only relaed to the notification part (pre and post actions), not the actual update.
Today I used it for the first time. Updating seems to work fine, but I’d like to receive a notification as well with the updates that are being installed. I use the ‘Pending_updates’ variable that should be available, but it doesn’t show in the notification (I just see the title):
service: notify.pushbullet
message: "{{ pending_updates }}"
title: HA updates are being installed
Am I missing something? I trigger the nofication in the ‘Pre-update actions’.
So, I’ve added support for selecting between “All”, “Patches only” or “Don’t update” for Core items, devices firmware and everything else, so now you can select exactly what you want to update.
Update HA déclenché par l'événement 'automation_reloaded'
11:56:22 - Il y a 2 heures
Auto-update Variables: input_backup_bool: False, input_restart_bool: False, input_schedule_monthday: 1, input_update_exclusions: ['update.nas_dsm_update'], input_core_os_update_mode: all, input_firmware_update_mode: ignore, updates_list: ['update.home_assistant_core_update', 'update.inter_echo_show', 'update.unifi_network_application_update'] déclenché par l'automatisation Update HA déclenché par l'événement 'automation_reloaded'
11:56:25 - Il y a 2 heures
Auto-update A new update is available for Home Assistant. déclenché par l'automatisation Update HA déclenché par l'événement 'automation_reloaded'
Auto-update List of updates: - Home Assistant Core Update - Inter echo show - UniFi Network Application Update déclenché par l'automatisation Update HA déclenché par l'événement 'automation_reloaded'
Auto-update Running pre-update actions... déclenché par l'automatisation Update HA déclenché par l'événement 'automation_reloaded'
Auto-update Starting sequence of standard updates... déclenché par l'automatisation Update HA déclenché par l'événement 'automation_reloaded'
Auto-update Updating UniFi Network Application Update of ['update.unifi_network_application_update'] ... déclenché par l'automatisation Update HA déclenché par l'événement 'automation_reloaded'
Auto-update Starting sequence of core items updates... déclenché par l'automatisation Update HA déclenché par l'événement 'automation_reloaded'
11:56:51 - Il y a 2 heures
Auto-update Updating Home Assistant Core Update of ['update.home_assistant_core_update'] ... déclenché par l'automatisation Update HA déclenché par l'événement 'automation_reloaded'
