Vacuum Cleaning Proposal — 3 choices
This blueprint sends an actionable mobile-app notification on a configurable schedule and lets you start a robot-vacuum clean with one tap. The notification offers three actions: full home, room group 1, or room group 2.
The blueprint is designed for vacuums that support vacuum.clean_area with cleaning_area_id, such as Roborock integrations exposing segment IDs. You configure the vacuum, Companion App notification target, schedule, button labels, and the segment lists for both room groups.
Features
- Configurable notification time and weekdays
- Uses the
notifyselector to choose a Companion App notification service - One full-clean action using
vacuum.start - Two configurable partial-clean actions using
vacuum.clean_area - Notification is dismissed after a button is tapped
- Custom title, message, icon, notification tag, and button labels
- Unique action IDs and notification tag per instance, allowing multiple independent vacuum proposals
Requirements
- A mobile device using the Home Assistant Companion App, as actionable notification buttons and
clear_notificationare mobile-app features - A vacuum integration supporting
vacuum.clean_area - Valid vacuum room/segment identifiers
Important note
The action IDs (VACUUM_FULL, etc.) are sent through the global mobile_app_notification_action event. If you create multiple instances of this blueprint, configure unique action IDs and a unique notification tag for every instance; otherwise, pressing one notification button may trigger more than one automation.
