Scheduler Blueprint
Control your switches via calendar events, program devices to turn on and off whenever you want. Even control from Google Calendar.
This blueprint will let you:
  • Control a switch with a calendar
  • Manually override the schedule
  • Run scripts when the switch is toggled
  • Run a periodic check script
  • Notify on important events (currently with a notify.* action, but hopefully it will be an entity soon)
blueprint:
  description: Turn on and off a device based on a calendar
  homeassistant:
    min_version: 2024.6.0
  domain: automation
  input:
    calendar:
      description: The calendar to monitor
      selector:
        entity:
          filter:
            - domain: calendar
    switch:
      description: The switch to control
      selector:
        entity:
          filter:
            - domain: switch
    mode:
      description: >-
        The input_select to control the mode (Modes: "Auto", "On", "Off")
      selector:
        entity:
          filter:
            - domain: input_select
    on_turn_on:
      name: On Turn On
      description: The actions to take when the switch is turned on
      default: []
      selector:
        action: {}
    periodic_check:
      description: The actions to take when the periodic check triggers
      default: []
      selector:
        action: {}
    on_turn_off:
      name: On Turn Off
      description: The actions to take when the switch is turned off
      default: []
      selector:
        action: {}
    notify:
      description: The notification entity to use
      selector:
        entity:
          filter:
            - domain: notify
    notification_title:
      description: The title to use for notifications
      default: Scheduler
      selector:
        text:
    notification_channel:
      description: The channel to use for notifications
      default: Scheduler
      selector:
        text:
    notification_tag_prefix:
      name: Notification Tag Prefix
      description: The prefix to use for notification tags
      default: scheduler
      selector:
        text:
    notification_action:
      description: URL to open on click.
      default: null
      selector:
        text:
mode: single
max_exceeded: silent
triggers:
  - entity_id:
      - !input calendar
    alias: Calendar State
    trigger: state
  - event: start
    trigger: homeassistant
  - event_type: AUTOMATION_RELOADED
    trigger: event
  - id: Periodic Check
    hours: /1
    trigger: time_pattern
  - event: start
    offset: "0:5:0"
    entity_id: !input calendar
    trigger: calendar
  - event: start
    offset: "-0:30:0"
    trigger: calendar
  - entity_id:
      - !input mode
    trigger: state
variables:
  calendar: !input calendar
  tag_prefix: !input notification_tag_prefix
actions:
  - choose:
      - conditions:
          - condition: trigger
            id:
              - State Change
          - condition: state
            state: "on"
          - condition: state
            entity_id: !input switch
            state: "off"
          - condition: state
            entity_id: !input mode
            state: Auto
        sequence:
          - metadata: {}
            data: {}
            action: switch.turn_on
          - data:
              message: Turned on automatically
              title: !input notification_title
                channel: !input notification_channel
                tag: "{{ tag_prefix }}_turned_on"
                chronometer: true
                when: >-
                  {{ state_attr(calendar, 'end_time') |
                  as_timestamp }}
                clickAction: !input notification_action
                url: !input notification_action
            action: !input notify
          - sequence: !input on_turn_on
        alias: When triggered by State Change to On
      - conditions:
            id:
              - State Change
          - condition: state
            state: "off"
          - condition: state
            state: "on"
          - condition: state
            state: Auto
        sequence:
          - target:
              entity_id:
                - !input switch
            data: {}
            action: switch.turn_off
          - data:
              message: Turned off automatically
                tag: "{{ tag_prefix }}_turned_off"
          - sequence: !input on_turn_off
        alias: When triggered by State Change to Off
      - conditions:
            id:
              - Ensure State
          - condition: state
            state: Auto
        sequence:
          - if:
              - condition: state
                state: "on"
            then:
              - target:
                data: {}
            else:
              - target:
                data: {}
        alias: Ensure State
      - conditions:
            id:
              - Periodic Check
          - condition: state
            state: "on"
        sequence: !input periodic_check
      - conditions:
            id:
              - Before
        sequence:
          - data:
                tag: "{{ tag_prefix }}_will_turn_on"
                chronometer: true
                when: >-
                  {{ state_attr(calendar, 'start_time') |
                  as_timestamp }}
              message: Will turn on soon
      - conditions:
            id:
              - Ensure State
          - condition: state
            state: "On"
        sequence:
          - action: switch.turn_on
            metadata: {}
            data: {}
      - conditions:
            id:
              - Ensure State
          - condition: state
            state: "Off"
        sequence:
          - action: switch.turn_off
              entity_id:
                - !input switch
            data: {}
Here is an example usage:
alias: Slow Cooker
description: ""
use_blueprint:
  path: scheduler.yaml
  input:
    calendar: calendar.slow_cooker
    switch: switch.kitchen_smart_plug
    mode: input_select.slow_cooker_mode
    notify: notify.slow_cooker
    notification_channel: Slow Cooker
    notification_tag_prefix: slow_cooker
    on_turn_on: []
    periodic_check:
      - if:
          - condition: numeric_state
            entity_id: sensor.kitchen_smart_plug_instantaneous_demand
            above: 10
        then:
          - data:
              title: Slow Cooker cooking!
              message: >-
                Power consumption is {{
                states('sensor.kitchen_smart_plug_instantaneous_demand') }} W
                tag: slow_cooker_cooking
            action: notify.slow_cooker
        else:
          - data:
              title: Slow Cooker Alert!
              message: >-
                Power consumption of {{
                states('sensor.kitchen_smart_plug_instantaneous_demand') }} W is
                too low
                tag: slow_cooker_alert
                clickAction: /dashboard-mobile/slow-cooker
                url: /dashboard-mobile/slow-cooker
                alert_once: true
    on_turn_off:
      - data:
          message: Would you like to broadcast?
          title: Slow Cooker
            tag: slow_cooker_turned_off_food_is_ready
            actions:
              - action: FoodIsReady
                title: Food is Ready!
    notification_title: Slow Cooker Scheduler
    notification_action: /dashboard-mobile/slow-cooker
Quick Start Guide
  1. Setup the Google Calendar or Local Calendar integration
  2. Import the blueprint Open your Home Assistant instance and show the blueprint import dialog with a specific blueprint pre-filled.
  3. Select your calendar entity and the switch to control (could be a smart plug or light or even template switch)
  4. Create a select helper Open your Home Assistant instance and start setting up a new integration. with options:
  • “On”
  • “Auto”
  • “Off”
  1. Select your notify.* service and configure the notifications
  2. Add scripts for events
  3. You’ve finished
Example Usage
  • Set a slow cooker/crock pot to come on
  • Schedule a light
  • Turn on a light during meetings
Happy Scheduling!!
Hi, many thanks for this Blueprint - it works really well for a use case I have!
And it's great to have a helper to allow auto/on/off modes. If you are still actively working on the blueprint could I suggest making the notification optional?
Hi Dan,
Before making modifications to the notifications, I'm waiting for the notify entities to be better. In a perfect world, you would use a target selector to choose 0 or more notifiers, but unfortunately they are not there yet.
Until then, I would recommend copying this blueprint to your instance and stripping out all of the notifications. Sorry that is a bit of an inconvenience, hopefully notify entities will be better soon.
Out of interest, what is your use case for this, I am still only using this in one place.
Cheers!
