Scheduler card/custom component
I tried this code but it don’t match with what i want.
I’d like to set up only 1 schedule for multiples of climate.
This code only include the climate i want to manage under entities but they’re still independant.
Maybe you could use climate_groups… (here) and schedule the group
  - platform: climate_group
    entities:
    - climate.thermostat_bureau
    - climate.thermostat_cuisine
    - climate.thermostat_hall
Can you share an example of code ?
i tried to add climate_group in schduler_card but i have a lot of errors.
Some of this should be split up over to groups, not domains. You misspelled “platform” as “plateform”.
I corrected “platform” but i don’t find what to split and how.
Actually just rename domains to groups and it should work.
Install the component climate_group and configure it. After you use tis as a climate thermostat
I still have issues
Check your indentation, and don’t take screenshots, actually copy the code and hit the format button.
I think i’m turning around but i don’t find what’s wrong.<
Here is my code :
type: 'custom:scheduler-card'
discover_existing: false
standard_configuration: false
title: Zone Nuit
time_step: 1
groups:
  climate:
      entities:
        - climate.thermostat_ch_parent
        - climate.thermostat_dressing
        - climate.thermostat_ch_hugo
        - climate.thermostat_ch_noa
      icon: thermometer
      actions:
        - service: set_temperature
          variable:
            field: temperature
            min: 15
            max: 23
            step: 0.5
        - service: set_hvac_mode
          service_data:
            hvac_mode: 'off'
          name: HVAC to Off
          service_data:
            hvac_mode: heat
          name: HVAC to Heat
        - service: set_preset_mode
          service_data:
            preset_mode: none
          name: Preset to None
          service_data:
            preset_mode: away
          name: Preset to Away
        - service: turn_on
        - service: turn_off
Add climate group on climate.yaml, not here !!!
Ok, thank for precisions.
I added a thermostat_nuit.yaml in my climate folder (i’va split my configuration).
But the new climate doesn’t appear in my Schedule Card.
this is the group. Climate group is a climate thermostat it’s contain multiples thermostats…
Here we’re talking about building a climate_group and as a result we’re a bit off topic…
Tank you, i forgot to add the include section.
I have another question :
can we use differents scheduler_card ?
for exemple, one for Climate, one for Lights, …
Yes of course but there is currently a bug on the title of the card…
Guys I would like to have more than one long scheduler card but have some various scheduler cards under different locations of my dashboard (garden irrigation schedule under garden, pump schedule under pool management etc…). I have tried to configure it with discover_existing but couldn’t get configured. What is the trick here?
The best trick is to wait one day. I am bringing out a release to simplify this :slightly_smiling_face:
That’s a solution I like! Thanks Neliss!
