Can anybody here help to make this repo build on github?
I’ve added a build action to my fork, but I’m unable to make it build. I’ve spent the whole day eliminating errors, but without success.
This is my first attempt to build any node / js stuff, but it seems to be a nightmare. After resolving package dependency errors, lint errors I was unable to resolve errors with rollup like semantic error TS2305: Module '"../node_modules/custom-card-helpers/dist"' has no exported member 'FrontendTranslationData'..
I’m sure I’m on a wrong track, so I’ve hard reset my fork to the beginning.
I have some MQTT button entities with entity id “button.XXXX”.
But I cannot find any button entity when adding entities to the include list.
Did I miss any steps?
Button component is relatively new. I didn’t add it to the card yet.
You could add it yourself if you want, using the customize configuration (YAML-only feature).
I hope you could help me with this. I have a heat pump that I control with automation with an external temperature sensor as a trigger. Can I somehow have the scheduler card control the heat pump by looking at the external temperature senor readings (not the one build-in into the pump).
@neliss Hi, suddenly the component doesn’t work with my installation. It worked this morning (my alarm scene fired off at 08.00) but after around 1-2 hours I noticed it said the card couldn’t connect to the Scheduler component. I then updated HA from 2022.5.2 to 2022.5.3 hoping it would solve it. Sadly it didn’t, also re-installing from HACS didn’t help. After restarting HA I noticed it came back very shortly and then was gone again. Log mentions this:
2022-05-11 11:18:40 INFO (MainThread) [homeassistant.components.switch] Setting up switch.scheduler
2022-05-11 11:18:40 WARNING (MainThread) [custom_components.scheduler.timer] failed to calculate next timeslot for schedule 4a413b
But nothing else mentions this component. In the past I noticed this issue very rarely, but refreshing the dashboard fixed it. Sou it was a front-end bug. But but it seems it’s a backend issue, since the log mentions it can’t calculate the next timeslot. The service calls of the component do work however. Using scheduler.run_action works.
Any idea what could be the issue and how to fix this / troubleshoot?
Could it be a schedule with an end date in the past?
If so, this bug may be related.
I actually made a fix for it this morning, but it’s not released yet.
This was indeed the issue. I read the ticket before but didn’t see the connection with my setup. After your feedback I realized I have created a schedule that’s only active this week and stops on this day (first time using this). So I deleted that schedule using the service call and indeed everything worked again.
I’ll update to the latest release when it becomes available and for now I will remove the date expiration of others. Thanks!
We found a custom integration scheduler which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
the installation was done properly.
Otherwise, check for a custom_components/scheduler folder. It should have been created (and filled) by HACS.
Also, you need to restart HA afterwards.
If the installation was done properly and still the integration doesn’t show up, it’s surely a cache issue. If emptying cache doesn’t work, try with a different browser/device. It’s a known quirk of HA.
I was seeing the stability message in the logs.
Poked around some more and discovered that although I was seeing HACS / Frontend / Scheduler Card - I had not yet added HACS / Integrations / Scheduler Component.
It’s there now as is the custom_components folder.
After restarting HA and still not seeing the Scheduler in the Add Integration list (under Firefox) I tried MS Edge - and there it was!!!
I am trying to create a scheme to turn a device on from 00:30 to 04:30.
However I cannot move the slider anything less than 0:40.
I can instead create separate turn on/turn off schedules as a workaround, but it would be nice to have this in one scheme.
In order to get to 00:05 (I have steps of 5min as config) I need my screen to be even wider. Not sure if this is something because of how HA operates, or if it’s a card bug. You should create a ticket regarding this on this Github’s repo.
I want to use this to send Telegram reminders to the entire family about when garbage and recyling need to go to the street for pickup. Recycling is every two weeks (aka every other week). Can I set something up to do something every other Monday evening?
Got a bunch of bugs since beta 2022.6 (maybe later than that, don’t know)
I can’t delete a schedule now and the switch entities made by scheduler integration are now “control” instead of “config” (so they also got exposed to google assistant and homekit)
