Scheduler Card + Fibaro Valve
Hi Everyone. My problem today is related to Scheduler Card. It works very well with my Blinds and Fibaro thermostats (valves) . Recently I decided to start move my zwave devices to Z-Wave JS. I started from my room in order to observe if something strange or specific will happen, before I move my whole instalation from Fibaro HC3 to Z-Wave JS. All devices within my room works very well including Fibaro valve with temperature sensor. I can change values, I can change mode, i can use valve without any problem. The one and only one but serious issue for me is that valve stop working with my Scheduler card. It means that all other valves which are managed by MQTT and HC3 reacts perfectly on schedule but not this one. Of course i removed old valve from HC3, changed values in scheduler card. I changed everything in terms of settings. I don’t know coding so i didn’t look into editor because for sure i won’t find anything. To summarize valve works manually, it is fully operational or remotely by thermostat card but doesn’t change values in scheduler card in selected time. It is related only to this valve .Other operate perfectly on schedule.
