Scheduler customizable
Hi, i’m now on ha and i’m considering to automate my home with ha. I need, in addition to classical features, a scheduler for program heating/cooling or any kind of things from UI. I’m looking for something like that, where i can add new entry, remove, modify scheduling time or day.
Where i can found help, how to o starting point to my problem?
thank you
There is no component to do this. You will have to set up your own. Here are some links to components you could use:
Using basic elements like this you can create groups like this:
Here are my automations for this timed thermostat.
- id: lounge_aircon_manual
  alias: 'Lounge Room Aircon'
  hide_entity: True
    platform: state
    entity_id: input_select.lounge_ac_mode
  - service_template: >
      {% if is_state('input_select.lounge_ac_mode', 'Powerful Heat') %} shell_command.lounge_ac_powerful_heat
      {% elif is_state('input_select.lounge_ac_mode', 'Normal Heat') %} shell_command.lounge_ac_normal_heat
      {% elif is_state('input_select.lounge_ac_mode', 'Silent Heat') %} shell_command.lounge_ac_silent_heat
      {% elif is_state('input_select.lounge_ac_mode', 'Powerful Cool') %} shell_command.lounge_ac_powerful_cool
      {% elif is_state('input_select.lounge_ac_mode', 'Normal Cool') %} shell_command.lounge_ac_normal_cool
      {% elif is_state('input_select.lounge_ac_mode', 'Silent Cool') %} shell_command.lounge_ac_silent_cool
      {% elif is_state('input_select.lounge_ac_mode', 'Dry') %} shell_command.lounge_ac_dry
      {% elif is_state('input_select.lounge_ac_mode', 'Off') %} shell_command.lounge_ac_off
      {% endif %}
- id: lounge_aircon_auto_am_on
  alias: 'Lounge Room Aircon Scheduled AM On'
    platform: template
    value_template: "{{ states('sensor.time') == (states.input_datetime.lounge_ac_am_on_time.state[0:5]) }}"
  condition:
    condition: and
    conditions:
      - condition: state
        entity_id: input_boolean.lounge_ac_am_automation # If automation is required and ...
        state: 'on'
      - condition: or
        conditions:
          - condition: state
            entity_id: input_boolean.lounge_ac_workday # If workday is not tested or is a workday
            state: 'off'
          - condition: state
            entity_id: binary_sensor.workday_sensor
            state: 'on'
  - service: input_select.select_option
    data_template:
      option: >
        {% if states.sensor.stats_roomt_mean.state < states.input_number.lounge_ac_heat_temp_set.state  %}
          Normal Heat
        {% elif states.sensor.stats_roomt_mean.state > states.input_number.lounge_ac_cool_temp_set.state  %}
          Normal Cool
        {% else %}
          'Off'
        {% endif %}
- id: lounge_aircon_auto_pm_on
  alias: 'Lounge Room Aircon Scheduled PM On'
    platform: template
    value_template: "{{ states('sensor.time') == (states.input_datetime.lounge_ac_pm_on_time.state[0:5]) }}"
  condition:
    condition: and
    conditions:
      - condition: state
        entity_id: input_boolean.lounge_ac_pm_automation # If automation is required and ...
        state: 'on'
      - condition: or
        conditions:
          - condition: state
            state: 'off'
          - condition: state
            state: 'on'
    data_template:
      option: >
          Normal Heat
          Normal Cool
        {% else %}
          'Off'
        {% endif %}
- id: lounge_aircon_auto_am_off
  alias: 'Lounge Room Aircon Scheduled AM Off'
    platform: template
    value_template: "{{ states('sensor.time') == (states.input_datetime.lounge_ac_am_off_time.state[0:5]) }}"
  condition:
    condition: and
    conditions:
      - condition: state
        state: 'on'
      - condition: or
        conditions:
          - condition: state
            state: 'off'
          - condition: state
            state: 'on'
    data_template:
      option: 'Off'
- id: lounge_aircon_auto_pm_off
  alias: 'Lounge Room Aircon Scheduled PM Off'
    platform: template
    value_template: "{{ states('sensor.time') == (states.input_datetime.lounge_ac_pm_off_time.state[0:5]) }}"
  condition:
    condition: and
    conditions:
      - condition: state
        state: 'on'
      - condition: or
        conditions:
          - condition: state
            entity_id: input_boolean.lounge_ac_workday # If workday not tested or if workday
            state: 'off'
          - condition: state
            state: 'on'
    data_template:
      option: 'Off'
