Hello, I’m trying to find a smart switch which would help me to automate some production function that involve scheduling seconds:
es ON 12:57:28 OFF 12:57:38 every day
It’s not important that is too precise… but for sure it must be shorter than 1 minute as most smart switch brands provides only this as shortest span. In order to avoid wasting again money on a switch that cannot serve me I’d like to ask in advance if you can confirm that through the use of a “Shelly” device and “Home Assistant” I will be able to perform such a thing… as I’ve read online but didn’t yet try.
Not sure I follow your question. Are you asking if you can have an automation turn a switch on for 10 seconds and then turn it off? If so, that’s a definite yes.
Yes exactly, but it’s not just a timer, because usually by “timer” some apps mean the devices turns on/off after x seconds (one time), but the schedule function still doesn’t involve seconds so I can’t use neither…
If you had bothered to look at the link I posted you would have seen it does support seconds.
- id: "on"
platform: time
at: "00:11:22" # can be replaced with a datetime helper
- id: "off"
platform: state
entity_id: switch.foobar
to: "on"
for:
seconds: 42 # can be replaced with a number helper
- service: "switch.turn_{{ trigger_id }}"
I did look it up, anyway you are right sorry, that’s exactly what I look for, I was just explaining in order to be sure 100%. Thank you for answering my doubts.
Now I’m having some troubles with the Linux installation though… is this also the right place to ask? Should I open another thread in installation? (I warn that I may ask stupid questions because I’m no expert, so sorry in advance!)
