Hi, how would a get the value for allow_manual_changes
from a HA helper?
Things that do not work:
allow_manual_changes: {{ is_state("input_boolean.heating_allowchanges", "on") }}
Templating does not seem to bee supported and the editor won’t even let me save it.
allow_manual_changes: "False if allow_changes() else True"
Schedy won’t initialize because that is not a bool and does not get evaluated like in the value / x.
allow_manual_changes: is_on("input_boolean.heating_allowchanges")
allow_manual_changes: "is_on('input_boolean.heating_allowchanges')"
allow_manual_changes: |
won’t get evaluated either.
Background: My Shelly TRVs have started to behave erratically and report back old values after getting a command from HA which then results in setting the new temperature after the rescheduling_delay. When manually setting the temperature, I want this delay; in most cases, I do not.
If someone has a fix for the TRVs I’d be even happier
Kind regards, Jörg
