I’m having a problem with schedule_prepend
in my schedy heating script. The relevant parts are:
schedule_prepend:
- x: "6 if house_mode() == 'Away' or season() == 'Summer' else Next()"
# default rule to apply if no other matches
schedule_append:
- v: 15
rooms:
livingroom:
rescheduling_delay: 0
replicate_changes: true
actors:
climate.livingroom_thermostat:
schedule:
- x: "15 if simulate_bedtime() == 'on' else Next()"
- v: 19
rules:
- weekdays: 1-5
rules:
- rules:
# - x: "Next() if season() == 'Spring' else Break()"
# - {v: 15, start: "23:00", end: "17:00+1d" }
# - { start: "17:00", end: "23:00" }
- x: "Next() if house_mode() == 'Home - Normal Day' else Break()"
- { start: "07:00", end: "09:00" }
- { start: "17:00", end: "19:00" }
- rules:
- x: "Next() if house_mode() == 'Home - Home Day' else Break()"
- { v: 19, start: "09:00", end: "17:00" }
- { start: "17:00", end: "22:30" }
- weekdays: 6-7
rules:
Oddly, the prepend is being ignored. From the log:
schedy_heating: --- [R:livingroom] Initializing room (name='livingroom').
schedy_heating: --- [R:livingroom] [A:climate.livingroom_thermostat] Initializing actor (entity_id='climate.livingroom_thermostat', type='thermostat').
schedy_heating: --- [R:livingroom] [A:climate.livingroom_thermostat] Fetching initial state.
schedy_heating: --> [R:livingroom] [A:climate.livingroom_thermostat] Attribute 'state' is 'heat'.
schedy_heating: --> [R:livingroom] [A:climate.livingroom_thermostat] Attribute 'temperature' is 15.0.
schedy_heating: --> [R:livingroom] [A:climate.livingroom_thermostat] Attribute 'current_temperature' is 21.6.
schedy_heating: --> [R:livingroom] [A:climate.livingroom_thermostat] Received value of 15.0��.
schedy_heating: --- [R:livingroom] [A:climate.livingroom_thermostat] Listening for state changes.
schedy_heating: --- [R:livingroom] Registering scheduling timers at: [00:00:00, 07:00:00, 09:00:00, 17:00:00, 19:00:00, 22:30:00]
schedy_heating: <-- [R:livingroom] Loading state of 'schedy_room.schedy_heating_livingroom' from Home Assistant.
schedy_heating: --> [R:livingroom] = {'entity_id': 'schedy_room.schedy_heating_livingroom', 'state': '15.0', 'attributes': {'actor_wanted_values': {'climate.livingroom_thermostat': '15.0'}, 'scheduled_value': '6.0', 'rescheduling_time': None, 'overlay_active': False}, 'last_changed': '2022-07-17T21:39:27.711702+00:00', 'last_updated': '2022-07-17T21:39:27.711702+00:00', 'context': {'id': '01G871M6AZ9BK05R8EAN6S9BBN', 'parent_id': None, 'user_id': '0ef99f16230e4d129335978c77d3c611'}}
schedy_heating: --- [R:livingroom] Evaluating room's schedule (reset=False, force_resend=False).
schedy_heating: --- [R:livingroom] Assuming it to be 2022-07-26 19:27:27.989153.
schedy_heating: --- [R:livingroom] ������ [SUB] <<Schedule 'livingroom'>/1:<Rule with sub <Schedule 'prepend'>>>
schedy_heating: --- [R:livingroom] ������ [ACT] <<Schedule 'livingroom'>/1/1:<Rule x="6 if house_mode() == 'Away' or season() "...>>
schedy_heating: --- [R:livingroom] Initializing expression helper: BasicHelper, order = 0
schedy_heating: --- [R:livingroom] Initializing expression helper: PatternHelper, order = 0
schedy_heating: --- [R:livingroom] Initializing expression helper: ScheduleHelper, order = 0
schedy_heating: --- [R:livingroom] Initializing expression helper: StateHelper, order = 0
schedy_heating: --- [R:livingroom] Initializing expression helper: ThermostatExpressionHelper, order = 0
schedy_heating: --- [R:livingroom] Initializing expression helper: CustomEnvironmentHelper, order = 1000
schedy_heating: --- [R:livingroom] Executing the expression_environment script.
schedy_heating: --- [R:livingroom] ������ => 6
schedy_heating: --- [R:livingroom] Final result: 6.0��, markers: set()
schedy_heating: --- [R:livingroom] Result didn't change, not setting it again.
schedy_heating: <-- [R:livingroom] Sending state to HA: state='15.0', attributes={'actor_wanted_values': {'climate.livingroom_thermostat': '15.0'}, 'scheduled_value': '6.0', 'rescheduling_time': None, 'overlay_active': False}
house_mode
is set to away
As you can see, it comes to the correect conclusion that the target should be set to 6C, but then does nothing about it.
Any ideas?
