Schlage Connect - door always open?
I have a Schlage Z-Wave Connect deadbolt and it works great.
However, it has a sensor of “current status of door” and it is always “open”. Even when its locked…see below:
Screenshot 2024-11-22 131858
Any one have any experience with these? I don’t understand why it’s always shown as “open”; again, even when it’s locked.
How does it detect open/closed? My old Nuki used to have a separate magnet, like a contact sensor - easy to set that too far away.
Did you install a door sensor at the same time you installed the lock? If no, then you don’t have a door sensor and you can disable the entity. The lock probably doesn’t support it.
