Just moved all my stuff over to a new install due to unrelated issues. Have everything up and running again except for my schlage connect. Its acting oddly.
I completely unpaired it then factory reset the lock then repaired it (securely). After first boot, the front end will correctly show it unlocked. Toggling it will lock the lock and update the front end, although in its locked state the toggle will have a glow around it.
Toggling it again to unlock it will unlock the lock but after that HASS only shows its state as locked going forward and toggling the button does nothing.
I have done the unpairing - repairing procedure twice and that doesnt seem to do much of anything. Any ideas?
Im getting the following errors:
2017-02-11 12:53:43.642 Error, Node044, ERROR: Dropping command, expected response not received after 1 attempt(s)
017-02-11 12:53:07.101 Warning, Node003, WARNING: Device is not a sleeping node.
2017-02-11 12:53:07.101 Error, Node003, ERROR: node presumed dead
2017-02-11 12:53:22.582 Error, Node040, ERROR: Dropping command, expected response not received after 1 attempt(s)
