Schlage Connect Lock Unregistered Node
Hi everyone,
I’ve been attempting top as a schlage lock to Hass.io. I have an aeotec z-stick S2 and first used in it’s normal enrolling process by removing the stick, pressing the button on the stick and pressing the button on the lock. This appeared to work from the stick’s perspective but the lock timed out and blinked red.
I tried two more times unsuccessfully and put the stick back in the Pi and fired up HA. Nothing appeared on the HA front end over multiple restarts. There are no new nodes listed in the Zwave Config page however if I check the log I can see three new nodes communicating with the stick (17, 18, 19).
After some more research I see I messed up by not having a network key setup for the stick. I’m fine starting over with the “add secure node” function. How, though, do I remove the three incorrectly added nodes that I see in the log if they never fully registered as nodes in HA and are all technically for the same device (schlage lock).
Thanks for any help you can provide.
