Schlage Connect Locks - HA Integration Needs Attention
Got it! Keeping old text just for refrence for others on what works and what did not work
    - service: input_text.set_value
      data_template:
        entity_id: >
              {% set object_id = trigger.to_state.entity_id %}
              {% set code_slot = "_".join(object_id.split("_")[3:-2]) %}
              {% set user_code_id = 'input_text.door_keypad_' ~ code_slot ~ '_code' %}
              {{ user_code_id }}
        value: '{{ range(1000, 9999) | random }}'
This is one of the last items, I cannot understand what’s going. Just never seems to trigger. Overall I want it to trigger on any of these three entiys are a value ot 16, 17, or 18. I figure I’d use a condition. I commented out the condition for testing, and it still did not run, so I figure there is something wrong with my trigger
  - alias: Keypad clear code after one time use code is used for 16 through 18
      - platform: state
        entity_id:
          - sensor.lock_front_door_deadbolt_alarm_level
          - sensor.lock_back_door_deadbolt_alarm_level
          - sensor.lock_garage_door_lock_alarm_level
    condition:
      - condition: template
        value_template: "{{ states.trigger.to_state.state in ['16', '17', '18'] }}"
      - service: script.turn_on
        data_template:
          entity_id: >
            {% set code_slot = states.trigger.to_state.state %}
            {{ 'script.door_keypad_' ~ code_slot ~ '_delete' }}
This is a similiar automation, and it’s working
  - alias: Keypad clear code after one time use is set to disabled for 16 through 18
      - platform: state
        to: 'Disabled'
        entity_id:
          - input_select.door_keypad_16_access_schedule
          - input_select.door_keypad_17_access_schedule
          - input_select.door_keypad_18_access_schedule
        data_template:
          entity_id: >
                {% set script_to_run = 'script.door_keypad_' ~ code_slot ~ '_delete' %}
                {{ script_to_run }}
Also I’m not seeing any errors in the logs,
I’ve looked at the state of these
and they are changing to 16. Not sure if the condition could use some work, but like I said for now, I’ve commented it out just to make sure that was not my problem and it made no difference, so I can come back to that.
Same results with this
      - platform: state
        entity_id:
        to: '16'
      - platform: state
        entity_id:
        to: '17'
      - platform: state
        entity_id:
        to: '18'
        data_template:
          entity_id: >
This is getting annoying, I can verify the value is changing to 16, but cannot see any evidince of this automation recoginizing it. Typos somewhere??
Remove the ā€œtoā€ in the trigger and add a log entry in the action to see whats going on? The equivalent of the old school printf for debugging…
I’ve not done. The log entry before. How does that work? Do you have any examples?
Thanks!!
Here is a snipped that should give the general overview:
 - service: logbook.log
      data_template:
           EXIT DOOR: {{ trigger.to_state.attributes.friendly_name }}
         message: >-
           {{ trigger.to_state.state | replace("on","open") | replace("off","closed") }}
Are you sure that the states on the to_state is a string?
EDIT: Also, remove the word ā€˜states’ before trigger
I would think this is what you need:
    condition:
        value_template: "{{ trigger.to_state.state in [16, 17, 18] }}"
EDIT: Now that I’m looking at your other non-working automation, it appears the problem is most likey the word ā€˜states’ before both your triggers. Triggers are not in your states. So when you use states first, you are saying I want the state from the trigger domain. Trigger domian doesn’t exist, trigger is an event.
Shouldn’t this have worked though?
      - platform: state
        entity_id:
        to: '18'
Also I removed the condition totally, and never got this to run.
Well that may be related to the state. Try this:
      - platform: state
        entity_id:
        to: 18
I also had this for the longest time and also never triggered
      - platform: state
        entity_id:
My understanding is that should trigger with any state change, right?
yes it should
That’s what I thought. That’s why I was working on the condition, but when I could not get it to fire, I just removed the condition, and still nothing. I confirmed that the value of the senors changed, and there were no errors, it just never ran. I’ll do some logging testing as suggested above.
Well it looks like it was an issue with state vs numberic state.
This worked
- alias: Keypad test for back door
    - platform: numeric_state
      entity_id:
      above: 15
      below: 17
  - service: notify.pushbullet_notifications
      message: "door code entered"
      - email/[email protected]
      title: "Testing of back door keypad"
Got the delete script working too!! Thanks for the help
        entity_id:
        above: 15
        below: 19
    condition:
    - condition: numeric_state
      entity_id: sensor.ha_runtime_in_minutes
      above: 1
          message: "door delete test "
          title: "Testing of delete script door keypad"
        data_template:
          entity_id: >
            {% set code_slot = trigger.to_state.state %}
I’m going to document a bit but hope to post the whole working package in the next day or so!
OK, I feel like I’m being lazy for asking, but either I’m tired, or this is just not coming to me. This really is the last part of the script, which I hope to post tonight, I realized I missed one part.
here is what I have
  - alias: Notify who unlocked door with timestamp
    - platform: state
      entity_id:
        - sensor.frontdoor_action
        - sensor.backdoor_action
      to: 'Keypad Unlock'
# This is for an FE599 Schalge lock, they handle events differntly, this will only trigger if a differnt code is used to unlock the door.
    - platform: state
      entity_id:
        - sensor.garagedoor_code
#    condition:
#   - condition: state
#     entity_id: input_select.house_mode
#     state: 'Away'
    condition:
      above: 1
    - delay:
        seconds: 2
      data_template:
        message: " At {{ as_timestamp (now()) | timestamp_custom('%I:%M %p') }} on {{ now().strftime('%d %b %Y') }} "
        title: "{{ trigger.to_state.attributes.friendly_name }} unlocked by {{ states.sensor.backdoor_code.state }}"
Problem is with this
I need it to be backdoor code if sensor.backdoor_action was the triger, and frontdoor_code if sensor.frontdoor_action was the trigger, for garage the trigger IS sensor.garagedoor_code, so I guess I could just use the state of the trigger for that one. I feel like I need a template in a template in a tempalte, haha.
Like inception with HA.
Can I implement this for a windows installation of HA?
I’d think so, but cannot say 100%. I cannot think of any reason why it would not work, there are no special installs needed, just standard zwave sensors, etc.
I mean you could do that here… You could map your response based on the friend_name or entity_id:
      data_template:
        title: >
           {% mapper = { 'sensor.frontdoor_action': 'sensor.frontdoor_code',
                         'sensor.backdoor_action' : 'sensor.backdoor_code',
                         'sensor.garagedoor_code' : 'sensor.garagedoor_code' } %}
           {{ trigger.to_state.attributes.friendly_name }} unlocked by {{ mapper[trigger.entity_id] }}
Nice, I have not used the mapper yet. Thanks.
I posted this same comment in general formum and would like to delete it. Is there anyway to delete a post?
Edit: I see mapper is just a variable.
Should it be?
{% set mapper =
Thanks again,
I want to display the state of the _code sensor, so this should work, right?
          {% set mapper = { 'sensor.frontdoor_action': 'states.sensor.frontdoor_code.state',
                            'sensor.backdoor_action' : 'states.sensor.backdoor_code.state',
                            'sensor.garagedoor_code' : 'states.sensor.garagedoor_code.state' } %}
