Schlage Connect Will Only Unlock
After wrestling with it for hours, I got my new lock sort of working. But it will only unlock the door. If it is already unlocked it does nothing. I suspect this is because it thinks the door is always locked…the slider does not change states after it unlocks. Any suggestions?
And a bonus question…anybody have a handy way of setting new codes? Remotely?
I think I’m running into the same issue. The button on the home page will send the unlock command (which works) but then goes back to showing locked. From developer tools > services I can send both lock and unlock commands, which work regardless of the status shown on the homepage. I think the lock status is not being updated for some reason. Here a section of my OZW log that contains an error. Maybe this is responsible?
2017-01-29 10:42:33.982 Error, Node002, ERROR: Dropping command, expected response not received after 1 attempt(s)
2017-01-29 10:42:33.982 Detail, Node002, Removing current message
2017-01-29 10:42:33.982 Detail, Node002, Notification: Notification - TimeOut
Did you ever fix this? Now Im having this issue…
I have not figured out a solution, sorry.
