Schlage Integration add settings access
I recently installed 3 Schlage Encode door locks and added the integration to HA. Works great, locking and unlocking, seeing status and battery level.
I would like to see if other settings could be accessed and changed, specifically auto-lock time, as I would like to automate things like leave the back patio doors unlocked while we are home, then at night set back to auto-lock after 1 minute or something like that.
I would be willing to help if I had access to the Schlage API.
Hi, not sure if I am stupid or not, but I installed the integration, used my cloud Schlage credentials, but don’t see any entry at all even though the login credentials worked. Any idea what that could be?
Sorry man, I don’t log in very often apparently. Only thing that comes to mind is that if you had the custom integration installed prior to this being included in the standard integrations, you had to remove that prior to adding the standard integration. Other than that I do not remember having any trouble, they came right up.
