So I’ve had a lot of issues with my Schlage lock and Home Assistant (some user error and some hardware). I got a replacement lock from Schlage recently and got it set back up yesterday. I am able to lock and unlock it from HA without any problems and it shows the correct state each time. When I manually lock or unlock, it will not change state in HA.
Here is the log from an unlock. There is one error where it can’t send to the Zwave stack.
2020-12-23 12:58:13.359 Detail, Node003, Received: 0x01, 0x08, 0x00, 0x04, 0x00, 0x03, 0x02, 0x98, 0x40, 0x2a
2020-12-23 12:58:13.359 Info, Node003, Received SecurityCmd_NonceGet from node 3
2020-12-23 12:58:13.359 Info, NONCES: 0x88, 0xc9, 0x4f, 0xe8, 0x33, 0xda, 0xc4, 0x93
2020-12-23 12:58:13.359 Info, NONCES: 0xb2, 0x5a, 0x17, 0x5a, 0x50, 0x79, 0x71, 0x48
2020-12-23 12:58:13.360 Info, NONCES: 0x35, 0x1c, 0x3d, 0x0c, 0x1a, 0x1e, 0x0c, 0xe8
2020-12-23 12:58:13.360 Info, NONCES: 0x3f, 0x1a, 0x79, 0x56, 0xb8, 0x50, 0xa7, 0x79
2020-12-23 12:58:13.360 Info, NONCES: 0xd7, 0xda, 0x11, 0x85, 0x12, 0x7d, 0x50, 0x7e
2020-12-23 12:58:13.360 Info, NONCES: 0xdb, 0x06, 0x7d, 0x03, 0x3f, 0x26, 0xaa, 0xb8
2020-12-23 12:58:13.360 Info, NONCES: 0x34, 0x4e, 0x30, 0x1d, 0xac, 0x5a, 0xd0, 0x7b
2020-12-23 12:58:13.360 Info, NONCES: 0x8c, 0xaf, 0xf0, 0x9c, 0x0c, 0xc6, 0x82, 0xcb
2020-12-23 12:58:13.360 Info, Node003, Sending (Send) message (Callback ID=0x01, Expected Reply=0x00) - Nonce_Report - 0x01, 0x11, 0x00, 0x13, 0x03, 0x0a, 0x98, 0x80, 0x88, 0xc9, 0x4f, 0xe8, 0x33, 0xda, 0xc4, 0x93, 0x05, 0x01, 0xb0:
2020-12-23 12:58:13.365 Detail, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-12-23 12:58:13.365 Detail, ZW_SEND_DATA delivered to Z-Wave stack
2020-12-23 12:58:13.475 Detail, Received: 0x01, 0x07, 0x00, 0x13, 0x01, 0x00, 0x00, 0x0b, 0xe1
2020-12-23 12:58:13.475 Detail, ZW_SEND_DATA Request with callback ID 0x01 received (expected 0x01)
2020-12-23 12:58:13.653 Detail, Node003, Received: 0x01, 0x23, 0x00, 0x04, 0x00, 0x03, 0x1d, 0x98, 0x81, 0xeb, 0x88, 0xb3, 0x5f, 0x58, 0xf7, 0x6b, 0x24, 0x9c, 0x21, 0xa5, 0xc4, 0xed, 0x4d, 0x43, 0xb5, 0x58, 0xd7, 0x88, 0x29, 0x08, 0xc9, 0x02, 0x72, 0x76, 0x06, 0x73, 0xa6
2020-12-23 12:58:13.653 Info, Raw: 0x98, 0x81, 0xeb, 0x88, 0xb3, 0x5f, 0x58, 0xf7, 0x6b, 0x24, 0x9c, 0x21, 0xa5, 0xc4, 0xed, 0x4d, 0x43, 0xb5, 0x58, 0xd7, 0x88, 0x29, 0x08, 0xc9, 0x02, 0x72, 0x76, 0x06, 0x73, 0xa6
2020-12-23 12:58:13.653 Detail, Node003, Decrypted Packet: 0x00, 0x71, 0x05, 0x16, 0x01, 0x00, 0xff, 0x06, 0x02, 0x00
2020-12-23 12:58:13.654 Info, Node003, Received Alarm report: type=22, level=1, sensorSrcID=0, type:Access Control event:2, status=255
2020-12-23 12:58:13.654 Detail, Node003, Refreshed Value: old value=21, new value=22, type=byte
2020-12-23 12:58:13.654 Detail, Node003, Changes to this value are not verified
2020-12-23 12:58:13.654 Detail, Node003, Setting Encryption Flag on Message For Command Class COMMAND_CLASS_DOOR_LOCK
2020-12-23 12:58:13.654 Detail, Node003, Queuing (Send) DoorLockCmd_Get (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x62, 0x02, 0x25, 0x41, 0xe0
2020-12-23 12:58:13.654 Detail, Node003, Refreshed Value: old value=1, new value=1, type=byte
2020-12-23 12:58:13.654 Detail, Node003, Refreshed Value: old value=0, new value=0, type=byte
2020-12-23 12:58:13.654 Detail, Node003, Refreshed Value: old value=1, new value=2, type=byte
2020-12-23 12:58:13.654 Detail, Node003, Notification: ValueChanged
2020-12-23 12:58:13.655 Detail, Node003, Notification: ValueChanged
2020-12-23 12:58:13.656 Detail, Node003, Notification: ValueChanged
2020-12-23 12:58:13.657 Detail,
2020-12-23 12:58:13.657 Info, Node003, Processing (Send) Nonce Request message (Callback ID=0x41, Expected Reply=0x04)
2020-12-23 12:58:13.657 Info, Node003, Sending (Send) message (Callback ID=0x41, Expected Reply=0x04) - Nonce_Get(DoorLockCmd_Get) - 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x98, 0x40, 0x05, 0x02:
2020-12-23 12:58:13.661 Detail, Node003, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-12-23 12:58:13.662 Detail, Node003, ZW_SEND_DATA delivered to Z-Wave stack
2020-12-23 12:58:14.344 Detail, Node003, Received: 0x01, 0x08, 0x00, 0x04, 0x00, 0x03, 0x02, 0x98, 0x40, 0x2a
2020-12-23 12:58:14.344 Info, Node003, Received SecurityCmd_NonceGet from node 3
2020-12-23 12:58:14.344 Info, NONCES: 0x88, 0xc9, 0x4f, 0xe8, 0x33, 0xda, 0xc4, 0x93
2020-12-23 12:58:14.345 Info, NONCES: 0xc1, 0x00, 0x3c, 0x42, 0x4b, 0xba, 0x26, 0x9a
2020-12-23 12:58:14.345 Info, NONCES: 0x35, 0x1c, 0x3d, 0x0c, 0x1a, 0x1e, 0x0c, 0xe8
2020-12-23 12:58:14.345 Info, NONCES: 0x3f, 0x1a, 0x79, 0x56, 0xb8, 0x50, 0xa7, 0x79
2020-12-23 12:58:14.345 Info, NONCES: 0xd7, 0xda, 0x11, 0x85, 0x12, 0x7d, 0x50, 0x7e
2020-12-23 12:58:14.345 Info, NONCES: 0xdb, 0x06, 0x7d, 0x03, 0x3f, 0x26, 0xaa, 0xb8
2020-12-23 12:58:14.345 Info, NONCES: 0x34, 0x4e, 0x30, 0x1d, 0xac, 0x5a, 0xd0, 0x7b
2020-12-23 12:58:14.345 Info, NONCES: 0x8c, 0xaf, 0xf0, 0x9c, 0x0c, 0xc6, 0x82, 0xcb
2020-12-23 12:58:14.345 Info, Node003, Sending (Send) message (Callback ID=0x01, Expected Reply=0x04) - Nonce_Report - 0x01, 0x11, 0x00, 0x13, 0x03, 0x0a, 0x98, 0x80, 0xc1, 0x00, 0x3c, 0x42, 0x4b, 0xba, 0x26, 0x9a, 0x05, 0x01, 0x1a:
2020-12-23 12:58:14.346 Detail, Node003, Received: 0x01, 0x04, 0x01, 0x13, 0x00, 0xe9
2020-12-23 12:58:14.346 Error, Node003, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2020-12-23 12:58:21.683 Detail, Node003, Received: 0x01, 0x07, 0x00, 0x13, 0x01, 0x00, 0x02, 0xde, 0x36
2020-12-23 12:58:21.683 Detail, Node003, ZW_SEND_DATA Request with callback ID 0x01 received (expected 0x01)
2020-12-23 12:58:21.683 Info, Node003, Request RTT 8025 Average Request RTT 4393
2020-12-23 12:58:21.765 Detail, Node003, Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x03, 0x0a, 0x98, 0x80, 0x5b, 0xce, 0x9e, 0x92, 0x13, 0x78, 0xbb, 0x52, 0xe1
2020-12-23 12:58:21.765 Info, Node003, Received SecurityCmd_NonceReport from node 3
2020-12-23 12:58:21.766 Info, Node003, Sending (Send) message (Callback ID=0x42, Expected Reply=0x04) - DoorLockCmd_Get (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x62, 0x02, 0x25, 0x42, 0xe3
2020-12-23 12:58:21.772 Detail, Node003, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-12-23 12:58:21.772 Detail, Node003, ZW_SEND_DATA delivered to Z-Wave stack
2020-12-23 12:58:21.882 Detail, Node003, Received: 0x01, 0x07, 0x00, 0x13, 0x42, 0x00, 0x00, 0x0c, 0xa5
2020-12-23 12:58:21.882 Detail, Node003, ZW_SEND_DATA Request with callback ID 0x42 received (expected 0x42)
2020-12-23 12:58:21.882 Info, Node003, Request RTT 8225 Average Request RTT 6309
2020-12-23 12:58:21.882 Detail, Expected callbackId was received
2020-12-23 12:58:21.987 Detail, Node003, Received: 0x01, 0x10, 0x00, 0x04, 0x10, 0x03, 0x0a, 0x98, 0x80, 0x22, 0x81, 0x42, 0xfa, 0x71, 0xab, 0xdb, 0xf9, 0x09
2020-12-23 12:58:21.987 Info, Node003, Received SecurityCmd_NonceReport from node 3
2020-12-23 12:58:21.987 Info, Node003, Sending (Send) message (Callback ID=0x43, Expected Reply=0x04) - DoorLockCmd_Get (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x62, 0x02, 0x25, 0x43, 0xe2
2020-12-23 12:58:21.995 Detail, Node003, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-12-23 12:58:21.995 Detail, Node003, ZW_SEND_DATA delivered to Z-Wave stack
2020-12-23 12:58:23.201 Detail, Node003, Received: 0x01, 0x07, 0x00, 0x13, 0x43, 0x00, 0x00, 0x79, 0xd1
2020-12-23 12:58:23.202 Detail, Node003, ZW_SEND_DATA Request with callback ID 0x43 received (expected 0x43)
2020-12-23 12:58:23.202 Info, Node003, Request RTT 9545 Average Request RTT 7927
2020-12-23 12:58:23.202 Detail, Expected callbackId was received
2020-12-23 12:58:23.282 Detail, Node003, Received: 0x01, 0x08, 0x00, 0x04, 0x00, 0x03, 0x02, 0x98, 0x40, 0x2a
2020-12-23 12:58:23.282 Info, Node003, Received SecurityCmd_NonceGet from node 3
2020-12-23 12:58:23.282 Info, NONCES: 0x88, 0xc9, 0x4f, 0xe8, 0x33, 0xda, 0xc4, 0x93
2020-12-23 12:58:23.282 Info, NONCES: 0xc1, 0x00, 0x3c, 0x42, 0x4b, 0xba, 0x26, 0x9a
2020-12-23 12:58:23.282 Info, NONCES: 0x0c, 0x28, 0x10, 0x12, 0x19, 0xdd, 0x9e, 0x05
2020-12-23 12:58:23.282 Info, NONCES: 0x3f, 0x1a, 0x79, 0x56, 0xb8, 0x50, 0xa7, 0x79
2020-12-23 12:58:23.282 Info, NONCES: 0xd7, 0xda, 0x11, 0x85, 0x12, 0x7d, 0x50, 0x7e
2020-12-23 12:58:23.282 Info, NONCES: 0xdb, 0x06, 0x7d, 0x03, 0x3f, 0x26, 0xaa, 0xb8
2020-12-23 12:58:23.282 Info, NONCES: 0x34, 0x4e, 0x30, 0x1d, 0xac, 0x5a, 0xd0, 0x7b
2020-12-23 12:58:23.282 Info, NONCES: 0x8c, 0xaf, 0xf0, 0x9c, 0x0c, 0xc6, 0x82, 0xcb
2020-12-23 12:58:23.282 Info, Node003, Sending (Send) message (Callback ID=0x01, Expected Reply=0x04) - Nonce_Report - 0x01, 0x11, 0x00, 0x13, 0x03, 0x0a, 0x98, 0x80, 0x0c, 0x28, 0x10, 0x12, 0x19, 0xdd, 0x9e, 0x05, 0x05, 0x01, 0x91:
2020-12-23 12:58:23.287 Detail, Node003, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-12-23 12:58:23.287 Detail, Node003, ZW_SEND_DATA delivered to Z-Wave stack
2020-12-23 12:58:23.656 Detail,
2020-12-23 12:58:23.656 Info, NONCES: 0x88, 0xc9, 0x4f, 0xe8, 0x33, 0xda, 0xc4, 0x93
2020-12-23 12:58:23.657 Info, NONCES: 0xc1, 0x00, 0x3c, 0x42, 0x4b, 0xba, 0x26, 0x9a
2020-12-23 12:58:23.657 Info, NONCES: 0x0c, 0x28, 0x10, 0x12, 0x19, 0xdd, 0x9e, 0x05
2020-12-23 12:58:23.657 Info, NONCES: 0xe3, 0x3f, 0x19, 0xaa, 0x5b, 0x0c, 0x09, 0x3b
2020-12-23 12:58:23.657 Info, NONCES: 0xd7, 0xda, 0x11, 0x85, 0x12, 0x7d, 0x50, 0x7e
2020-12-23 12:58:23.657 Info, NONCES: 0xdb, 0x06, 0x7d, 0x03, 0x3f, 0x26, 0xaa, 0xb8
2020-12-23 12:58:23.657 Info, NONCES: 0x34, 0x4e, 0x30, 0x1d, 0xac, 0x5a, 0xd0, 0x7b
2020-12-23 12:58:23.657 Info, NONCES: 0x8c, 0xaf, 0xf0, 0x9c, 0x0c, 0xc6, 0x82, 0xcb
2020-12-23 12:58:23.657 Info, Node003, Sending (Send) message (Callback ID=0x01, Expected Reply=0x04) - Nonce_Report - 0x01, 0x11, 0x00, 0x13, 0x03, 0x0a, 0x98, 0x80, 0xe3, 0x3f, 0x19, 0xaa, 0x5b, 0x0c, 0x09, 0x3b, 0x05, 0x01, 0xe2:
2020-12-23 12:58:23.657 Detail, Node003, Notification: Notification - TimeOut
2020-12-23 12:58:23.662 Detail, Node003, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-12-23 12:58:23.662 Detail, Node003, ZW_SEND_DATA delivered to Z-Wave stack
2020-12-23 12:58:27.603 Detail, Node003, Received: 0x01, 0x07, 0x00, 0x13, 0x01, 0x00, 0x01, 0x8b, 0x60
2020-12-23 12:58:27.604 Detail, Node003, ZW_SEND_DATA Request with callback ID 0x01 received (expected 0x01)
2020-12-23 12:58:27.604 Info, Node003, Request RTT 3947 Average Request RTT 5937
2020-12-23 12:58:27.674 Detail, Node003, Received: 0x01, 0x07, 0x00, 0x13, 0x01, 0x00, 0x01, 0x92, 0x79
2020-12-23 12:58:27.674 Detail, Node003, ZW_SEND_DATA Request with callback ID 0x01 received (expected 0x01)
2020-12-23 12:58:27.674 Info, Node003, Request RTT 4016 Average Request RTT 4976
Am I doing something wrong?
