I have installed a Schlage sense smart deadbolt which works with their app on my iPhone and it appears to use Blue Tooth. They have a module that reads the blue tooth and converts to wifi. They also say Apple TVs and Apple Homekit can do the translation.
Has anyone got one working with Hassio? Any help tieing this to HA will be appreaciated.
Doug
Hi. I’m also looking at the Schlage Sense Smart deadbolt + Adapter as a solution also. I haven’t purchased anything as yet though and would rather know that it will work before doing so.
One more try asking.
I’m thinking of getting a Sense and linking to iPhone/Apple stuff, and wondering if I can get HA integration.
One thing I’ve noticed recently is that the lock can be used with Alexa and Google Assist… Does that help with integration?
Hello
I have both Schlage Sense and WiFi adapter, it connect my door to google assistant (just closing it), Yonomi to unlock and lock ok, no more homekit with the WiFi adapter.
It would be great to have some sort of integration to home assistant, either via Schalge account or directly command the WiFi adapter.
Next Monday I will try to capture the WiFi frame in order to clone the command but with I have no hope that I can manage that by myself,
Some help will be appreciated
See you
Hi, I’m just reposting to this thread as it’s over a year old, but I still haven’t seen anywhere a solution to get the Schlage Sense w/ WiFi and NO Homekit to be integrated with Home Assistant. Any help is appreciated, as this is driving me crazy.
So I found a workaround solution that satisfies my needs. My method doesn’t have a lot of finesse, but it worked for me.
In the Helpers, I set up a Boolean Switch. I then created an automation triggered of that state of the boolean switch going from ‘off’ to ‘on’.
And then in the Alexa app, I set it up so Alexa calls the Boolean Switch, so it triggers the automation in Home Assistant.
This was useful, so now I can say “Alexa Goodnight”, and Alexa locks the front door and then closes the garage door using HA. If this wasn’t clear, let me know, as I’m very new to HA, but happy I was able to kluge together an integration. It doesn’t show the status of the front door on HA, but at least gives me a way to guarentee it locks at night integrated with other components of HA.
Since there is support for the lock via HomeKit; are you not able to control the lock via the HA & HomeKit integration?
I have never setup the HomeKit integration before, but we are building a new house that will have the following:
I wanted to make sure I’m able to integrate the lock into HA before we purchase the above.
