Hello there,
I installed the Schneider blind control switch (here is the official technical PDF : https://download.schneider-electric.com/files?p_Doc_Ref=S5x0567W_HW )
It is correctly paired in HASS OS. Up/down/stop buttons work as intended. So far so good.
The “cover” feature and the open/closed status are confusing:
- if I click on “up” button and check what’s happening on cover status, it animates toward closed status (decreasing percentage) but with “opening” label (the log says it’s opening). And vice versa.
- if I trigger an opening/closing via the icon, it does the contrary: if I slide to the full open status, it starts to close the blind, and vice versa.
- where is the calibration or something I could manually set, did I miss it? The time allocated to opening/closing the blind is way too high.
Thanks for any help
