Schneider/ Wiser dimmer puck cannot turn on/off from home assistant
I have a weird issue. Im using zigbee2mqtt and trying to connect a device (Schneider/ Wiser dimmer puck) I can see everything that happens when it’s controlled manually.
I have one device that is connected and working with home assistant and can be controlle from it. I have another device, that is connected to mqtt but I cannot control it through home assistant. When I trigger manually the device changes state in home assistant and I get the update there. But I cannot change state from home assistant.Capture
I get the following error mistake.
I have no idea what I can do or what is wrong
@cpoulsen2 did you find a solution? I’m facing the same issue.
Same for me as well
