So why doesn’t this work as I expect it to? i.e. why doesn’t lowest show the lowest value of item.state at the end?
{% set lowest = states('sensor.latest_tasmota_version')[1:] %}
lowest before for loop is {{ lowest }}
{%- for item in states
if item.entity_id.split(".")[1].startswith('sonoff') and
item.entity_id.split(".")[1].endswith('firmware') and
item.state != 'unknown' %}
{% if item.state < lowest %}
{% set lowest = item.state -%}
lowest is {{ lowest }}
{% endif %}
{%- endfor %}
lowest after for loop is {{ lowest }}
Please note that assignments in loops will be cleared at the end of the iteration and cannot outlive the loop scope. Older versions of Jinja2 had a bug where in some circumstances it appeared that assignments would work. This is not supported. See Assignments for more information about how to deal with this.
Post your working code and mark either it or @pnbruckner 's reply as a solution. I have a feeling you won’t be the only one to hit this snag and a visual example is always a better learning tool than the docs
EDIT: Following on from the post that follows this one from @pnbruckner I have edited this one to add the line
entity_id: sensor.time
to the template sensor.
For anyone coming along reading this with the same issue I had, this post now contains a fully working solution. Ignore where it says ‘But in HA it doesn’t…’ It now works perfectly as given in this post.
@anon43302295 Yes absolutely, I couldn’t agree more and planned to do that this morning after getting it fully set up in my config. That response to @pnbruckner was posted after quick testing in the config tool last night which now appears to have been a bit premature…
So,
In the templating tool this works perfectly (screen capture below)
{% set ns = namespace(lowest = states('sensor.tasmota_current_version')[1:]) %}
{% for item in states if item.entity_id.split(".")[1].endswith('firmware') and
item.state != 'unknown' and
item.state < ns.lowest %}
{% set ns.lowest= item.state %}
{% endfor %}
v{{ ns.lowest }}
But in HA it doesn’t. It still returns the original value as set up outside the for loop.
Here are my sensors:
# Latest Sonoff Tasmota firmware version
- platform: command_line
name: Tasmota Current Version
command: "curl -s https://github.com/arendst/Sonoff-Tasmota/releases/latest | cut -d'\"' -f2 | rev | cut -d'/' -f1 | rev"
scan_interval: 86400
# Earliest Sonoff Tasmota firmware version
sensors:
tasmota_earliest_installed_version:
friendly_name: Tasmota Earliest Installed Version
value_template: >
{% endfor %}
v{{ ns.lowest }}
# Installed firmware version
- platform: mqtt
state_topic: "stat/sonoff01/STATUS2"
value_template: "{{ value_json.StatusFWR.Version }}"
- platform: mqtt
state_topic: "stat/sonoff02/STATUS2"
...and so on for every Sonoff device
Result as displayed in Lovelace
For completeness here are the entities as defined in Lovelace
- entity: sensor.tasmota_current_version
- entity: sensor.tasmota_earliest_installed_version
And here is the screenshot of templating tool showing correct output
I think you’ve been bit by the new classic template sensor problem. The automatic entity_id parsing for sensor.tasmota_earliest_installed_version is only finding sensor.tasmota_current_version, so it will only update at startup, and then only when sensor.tasmota_current_version changes. However, it looks like you also want it to update whenever other entities (i.e., ones whose object_id starts with “sonoff” and ends with “firmware”) update. So you either have to manually list all the entity_id’s the template sensor needs to watch, or you need to get it to update often (such as manually listing sensor.time.)
