Scrape a website
Still working on my plan to migrate from Jeedom to Home Assistant, I have a couple of things left to do, including this:
Retrieving information from a website using the Scrape integrator.
The website is Horoscoop, Rachel’s Horoscope - Radio SCOOP
Here is the configuration that does not work.
Pics of like
Text
Can you help me? Thank you
I’ve tried several things but nothing is working. Can you help me?
Thanks in advance.
  - sensor:
      - name: "Horoscope Debug HTML"
        state: >-
          {% set content = state_attr('sensor.horoscope_raw_data', 'content') %}
          {{ content[0:200] }}  # Affiche les 200 premiers caractères
      # --- Compteurs d'icônes ---
      - name: "Horoscope Amour (Icônes)"
        unit_of_measurement: "❤️"
        state: >-
          {{ content.split('horo_amour.png').length - 1 if content else 0 }}
      - name: "Horoscope Santé (Icônes)"
        unit_of_measurement: "💪"
        state: >-
          {{ content.split('horo_sante.png').length - 1 if content else 0 }}
      - name: "Horoscope Travail (Icônes)"
        unit_of_measurement: "💼"
        state: >-
          {{ content.split('horo_travail.png').length - 1 if content else 0 }}
      # --- Texte principal ---
      - name: "Horoscope Texte Principal"
        state: >-
          {% if content %}
            {% set start = content.find('horo_travail.png') + 15 %}
            {% set end = content.find('Tirage Belline') %}
            {% if start != -1 and end != -1 %}
              {{ content[start:end] | replace('<br>', ' ') | replace('\n', ' ') | trim }}
            {% else %}
              "Texte non disponible"
            {% endif %}
          {% else %}
            "Chargement..."
          {% endif %}
      # --- Tirage Belline ---
      - name: "Horoscope Tirage Belline"
        state: >-
          {% if content %}
            {% set start = content.find('Tirage Belline') + 14 %}
            {% set end = content.find('RACHEL CONSEILS') %}
            {% else %}
              "Tirage non disponible"
            {% endif %}
          {% else %}
            "Chargement..."
          {% endif %}
# Début Horoscope ----------------------------------------------------------
rest:
  - resource: "https://www.radioscoop.com/horoscoop.php?id=19"
    scan_interval: 3600
    headers:
      User-Agent: "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/91.0.4472.124 Safari/537.36"
      Accept: "text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8"
      Accept-Language: "fr-FR,fr;q=0.9,en-US;q=0.8,en;q=0.7"
      - name: "Horoscope Raw Data"
        value_template: "OK"
        json_attributes_path: "$"
# Fin Horoscope ----------------------------------------------------------
multiscrape:
  - name: radioscoop_horoscope
    resource: "https://www.radioscoop.com/horoscoop.php?id=19"  # ID 19 = Sagittaire (à adapter)
    scan_interval: 3600  # Met à jour toutes les heures
      - unique_id: horoscope_sagittaire  # Identifiant unique pour Home Assistant
        name: "Horoscope Sagittaire"     # Nom du sensor
        select: "#hJour9"                # Sélecteur CSS pour extraire l'horoscope
        value_template: "{{ value | regex_replace('<[^>]*>', '') | trim }}"  # Nettoie le HTML
        attributes:  # (Optionnel) Pour extraire d'autres infos si besoin
          - name: "amour"
            select: ".amour"  # Exemple : si tu veux extraire une section "Amour"
multiscrape:
    scan_interval: 3600
    headers:
      User-Agent: "Mozilla/5.0"
        select: "#hJour9"
        value_template: >-
          {% set raw_text = value %}
          {% set clean_text = raw_text.split('Tirage de cauris')[0] | trim %}
          {% set parts = clean_text.split('Travail') %}
          {% set travail = parts[1] | regex_replace('[\n\s]+', ' ') | trim %}
          {% set parts = parts[0].split('Santé') %}
          {% set sante = parts[1] | regex_replace('[\n\s]+', ' ') | trim %}
          {% set parts = parts[0].split('Amour') %}
          {% set amour = parts[1] | regex_replace('[\n\s]+', ' ') | trim %}
          {{ (amour + " " + sante + " " + travail) | trim | truncate(255) }}
        attributes:
          - name: "amour"
            value_template: >-
              {% set parts = clean_text.split('Amour') %}
              {{ parts[1].split('Santé')[0] | regex_replace('[\n\s]+', ' ') | trim }}
          - name: "sante"
            value_template: >-
              {% set parts = clean_text.split('Santé') %}
              {{ parts[1].split('Travail')[0] | regex_replace('[\n\s]+', ' ') | trim }}
          - name: "travail"
            value_template: >-
              {{ parts[1] | regex_replace('[\n\s]+', ' ') | trim }}
Nailed it
command_line:
  - sensor:
      unique_id: horoscope_complet_json
      icon: mdi:zodiac-sagittarius
      # On remplace <br> par \n\n pour forcer le saut de ligne dans la carte Markdown
      command: >
       curl -s 'https://www.radioscoop.com/horoscoop.php?id=19' | python3 -c "import sys, re, json; h = sys.stdin.read(); amour = h.count('horo_amour.png'); sante = h.count('horo_sante.png') + h.count('horo_forme.png'); travail = h.count('horo_travail.png'); m = re.search(r'style=\"font-weight:bold ; font-size:20px ; font-style:italic ; padding:10px\">([\s\S]*?)<\/div>', h); t = m.group(1) if m else 'Non disponible'; t = re.sub(r'<br\s*/?>', '\n', t); t = re.sub(r'<[^>]+>', '', t); t = re.sub(r'\n+', '\n', t).strip(); print(json.dumps({'amour': amour, 'sante': sante, 'travail': travail, 'texte': t}));"
      value_template: "Mis à jour"
      scan_interval: 86400
      json_attributes:
        - amour
        - sante
        - travail
        - texte
