I’m trying to get access to the web data for my outdoor wood boiler’s integrated web server. I can access the data via the web browser, but it requires authentication.
The website looks like:
and the code:
The username doesn’t change, it is already set and the password is just a default password.
I tried:
platform: scrape
resource: http://192.168.10.15
authentication: basic
username: ‘Web User’
password: heatmaster
But the logfile just says:
2022-11-20 20:00:44.061 WARNING (MainThread) [homeassistant.components.scrape.sensor] Index ‘0’ not found in sensor.furnace
I tried without the username and still get the same error.
This makes me believe that it didn’t authenticate.
Anyone know what I’m doing wrong?
thanks
Sigogglin:
The scrape
integration does not support form based authentication.
When you manually log in via the browser, can you see request headers being sent from your browser that contain an authentication token? If so, you could try setting that using the headers
parameter, and hope the token does not expire.
Is there something that does?
thanks
I am able to get logged in using the multiscrape custom addon.
Form submit functionality · danieldotnl/ha-multiscrape Wiki · GitHub
- name: Furnace
resource: http://192.168.10.15/logo_td_01.shtm
scan_interval: 60
form_submit:
submit_once: True
select: "#input_password"
input:
password: "heatmaster"
- unique_id: loginPage
select: '#desktopUserName > h2:nth-child(1)'
- unique_id: loggedIn
select: "#desktopUserName > p:nth-child(2) > a:nth-child(1)"
- unique_id: siemenslogo
select: "#logo_iPad"
I’m able to get values on the form that require you to be logged in. So this appears to be working for me.
goetzpil
(Goetzpil)
July 19, 2023, 3:11pm
5
I did copy most of your config code and did adapt it to mine, but it does not work.
Maybe you can help me: New setup does not work · Issue #224 · danieldotnl/ha-multiscrape · GitHub
FrankyHA
(Frank)
June 27, 2024, 9:14am
6
Hello @goetzpil , do you have found a solution to login and grap the date from your viessmann page?
Thanks in advance for you reply.
BR
