Is it possible to have a custom/dynamic resource URL whilst using the scrape?
resource: https:EXAMPLE.COM="{{ states('input_text.example') }}"
I don’t think I’ve explained this very well…
If I wanted to pull the weather back for UK, the URL may look like… www.example.com=UK
I’m wanting to determine what the ‘UK’ is by typing it into the text box…
Is this possible?
You can’t template the resource. So, to answer your question: No.
Perfect, thanks Petro
I’ll try finding another solution, unless anybody could advise further.
Thanks!
I’ll give this a go shortly… Don’t suppose you have any examples?
There’s an example in the docs? And the options say you can use resource_template instead of resource… what more do you need?
Chill. Chill… I’ll go read the docs
