Scrape information from car sell website
How can I scrape information from this example website link using using scrape sensor
Can someone show me example how to get text and pic from website on link?
We need more information and an example of what you already tried and what errors are produced.
Sorry @anon34565116.
I try to get number of results for a start.
I try like this but not working:
  - platform: scrape
    resource: https://www.avto.net/Ads/results.asp?znamka=Alfa%20Romeo&model=GT&modelID=&tip=katerikoli%20tip&znamka2=&model2=&tip2=katerikoli%20tip&znamka3=&model3=&tip3=katerikoli%20tip&cenaMin=0&cenaMax=999999&letnikMin=0&letnikMax=2090&bencin=0&starost2=999&oblika=0&ccmMin=0&ccmMax=99999&mocMin=&mocMax=&kmMin=0&kmMax=9999999&kwMin=0&kwMax=999&motortakt=&motorvalji=&lokacija=0&sirina=&dolzina=&dolzinaMIN=&dolzinaMAX=&nosilnostMIN=&nosilnostMAX=&lezisc=&presek=&premer=&col=&vijakov=&EToznaka=&vozilo=&airbag=&barva=&barvaint=&EQ1=1000000000&EQ2=1000000000&EQ3=1000000000&EQ4=100000000&EQ5=1000000000&EQ6=1000000000&EQ7=1110100120&EQ8=1010000001&EQ9=100000000&KAT=1010000000&PIA=&PIAzero=&PSLO=&akcija=&paketgarancije=&broker=&prikazkategorije=&kategorija=&zaloga=&arhiv=&presort=&tipsort=&stran=
    select: '.ResultsAdTopLeft Left'
I have not used the scrape sensor myself. Let me see if I can figure it out.
Does this give you the results you wish? I replaces the space in the last line with a .
  - platform: scrape
    select: '.ResultsAdTopLeft.Left'
The sensor returns Zadetki 1 - 15 od skupno 15
Thanks @anon34565116.
Can I have two result in one scrape sensor?
I tryed like this, bur not working:
  - platform: scrape
    select: '.ResultsAdDataTop .ResultsAdPrice'
    index: 0
I do not know. That was the first time I used that sensor. You may need 2 sensors & combine the data.
Here is example witch shows two data:
  - platform: scrape
    resource: http://www.bom.gov.au/vic/forecasts/melbourne.shtml
    name: Melbourne Forecast Summary
    select: ".main .forecast p"
    value_template: '{{ value | truncate(255) }}'
    # Request every hour
    scan_interval: 3600
    headers:
      User-Agent: Mozilla/5.0
Why my sensor shows unknown?
What have you tried? I see your example uses double quotes & yours has single quotes, for example.
I already try this still same result. Any idea?
I get error:
Unable to extract data from HTML
How I can remove same text from sensor using value template?
I have sensor:
  - platform: scrape
    select: '.ResultsAd'
    index: 0
I get this output:
Alfa Romeo GT 2.0 JTS Distinctive Letnik 1.registracije:2004 215000 kmbencinski motor, 1970 ccm, 122 kW / 166 KMroèni menjalnik (5 pr.) Ogled oglasa Parkiraj v moj.avto.net
 1.600
How I can remove text Ogled oglasa Parkiraj v moj.avto.net from sensor using value_template?
