Here is an example of what the configuration page looks like: http://62.147.201.147/http/index/j_modus.html
I am now trying to send the same post to my heat pump via Postman, which is necessary to switch from summer to party, for example.
I would like to make most of the settings for the heat pump from Home Assistant.
Hi. How is it going with your heat pump? I have a Dimplex heat pump that I want to control remotely. What age or model heat pump is yours? Mine is quite old, 14 years, but has a Carel controller inside like I guess most do. I don’t have a pcoweb LAN module currently. I’m at the start of my Home Assistant journey and trying to understand what the potential is for controlling my heat pump before investing in pcoweb interface board. Thanks, Mark
hi mark,
did you find out how to control heat pump. I have the same hardware and would like to integrate the system.
greetz
