Scrape not in configuration.yaml
Hallo Community,
Where do I find the yaml code of scrape integration? The documentation points to configuration.yaml but here is nothing about my running scrape sensor.
I would like to change the update frequency using scan_interval which is not available in the user interface.
All best
Dirk
If it’s not in configuration.yaml, you probably set it up via the UI.
Look in your integration page.
I didn’t find a field for the update frequency. I read the integration page before I posted this thread and they always show yaml code which I didn’t find in home assistant.
The UI configured sensors do not have the update interval option. You can either set the sensor back up in configuration.yaml where you can set the scan_interval option or setup an automation to run the update entity service call against the existing one.
Thanks!
Automation works. I will now set it up in configuration.yaml due to a longer scan_interval.
