I’m trying to create a scrape sensor to pull the air quality index from this site.
http://www.nyaqinow.net/StationInfo6.aspx?ST_ID=63
I’ve tried #current-index > h2 > div as the select but the sensor keeps reading “Unknown”
Any ideas?
Any ideas?
This is the HTML snippet that you are getting with that selector, and there is no data there. I assume the numeric value is injected via JavaScript, so the scrape integration won’t help you here.
<div id="current-index">
<h2>Current Air Quality Index</h2>
<a href="IndexPollutionBoard.aspx?ST_ID=63" id="IndexPollutionBoardLink">
<div id="index-gauge"></div>
</a>
</div>
However, you might be in luck, because it appears that the actual numeric value is stored in a hidden HTML snippet at the bottom of the page:
<div id="index">73</div>
So, maybe try #index
as selector.
Awesome, by using #index
as the select and adding User-Agent: Mozilla/5.0 to the header it works.
Thank you!
