First time user of the Scrape sensor, but when I try it out I got this error in the log:
Log Details (ERROR)
Wed Aug 29 2018 07:31:46 GMT+0200 (sentraleuropeisk sommertid)
scrape: Error on device update!
File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py", line 248, in _async_add_entity
await entity.async_device_update(warning=False)
File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 322, in async_device_update
yield from self.hass.async_add_job(self.update)
File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/sensor/scrape.py", line 120, in update
value = raw_data.select(self._select)[0].text
IndexError: list index out of range
This is My config:
- platform: scrape
resource: https://www.jotta.no/jfs/myusername
select: “.usage”
unit_of_measurement: Byte
authentication: basic
username: myusername
password: mypassword
This is the top of the xml I will scrape:
<user time=“2018-08-29-T05:13:42Z” host=“Backup2-backup2-get-oldgluster-dp1-5”>
<username>myusername</username>
<account-type>unlimited</account-type>
<locked>false</locked>
<capacity>-1</capacity>
<max-devices>-1</max-devices>
<max-mobile-devices>-1</max-mobile-devices>
<usage>11645076007480</usage> <–this
_<read-locked>fals_e</read-locked>
<write-locked>false</write-locked>
<quota-write-locked>false</quota-write-locked>
<enable-sync>true</enable-sync>
<enable-foldershare>true</enable-foldershare>
<devices>
This is my setup:
Hass.io supervisor
Version 127
Latest version 127
Host System
Hostname Home-Assistant
System Ubuntu 16.04.5 LTS
Home Assistant 0.76.2
