A tool like Firebug will help you spot the underlying HTML of the page.
Add to that that the page is a bunch of iframes. You’re going to need to determine the URL for the iframed document that you need data from and target that.
But even in that doc, I don’t see “Wasserstand [cm]” in the source…
This is also going to be messy if it’s just in a
tag without a class or ID. You’re likely going to have to do some counting (nth of type). And you won’t get it from a tag since s aren’t containers. You’ll need to target that
tag. Then split your results on spaces. And hope the format of that page stays consistent (so the nth counting never changes).
Hmm. And looking at that page, it looks like some of the values are populated by javascript - I don’t think you can scrape those.
