My scrape sensors were previously working fine. I’ve just noticed I wasn’t getting updates and I have the following error in the logs. Can anyone help?
scrape: Error on device update!
File "/usr/src/app/homeassistant/helpers/entity_platform.py", line 248, in _async_add_entity
await entity.async_device_update(warning=False)
File "/usr/src/app/homeassistant/helpers/entity.py", line 319, in async_device_update
yield from self.hass.async_add_job(self.update)
File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/usr/src/app/homeassistant/components/sensor/scrape.py", line 120, in update
value = raw_data.select(self._select)[0].text
IndexError: list index out of range
what does your scrape sensor config look like? This error seems to be the result of something else going wrong, maybe a previous exception. What lines are before this in the log?
This is one of them. The only other errors I have relate to warnings a bout custom components. I have tried removing all the custom components to see if they are the issue but I still get the same error
- platform: scrape
scan_interval: 360
resource: https://github.com/nextcloud/server/releases
select: "#js-repo-pjax-container > div.container.new-discussion-timeline.experiment-repo-nav > div.repository-content > div.position-relative.border-top > ul > li:nth-child(1) > div > div > h3 > a > span"
Edit: setup of config is taking over 10 seconds immediately precedes it.
The custom complements in the logs are warnings not errors as well
core-ssh:/config# cat home-assistant.log
2018-08-21 22:17:47 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.scrape
2018-08-21 22:17:48 DEBUG (SyncWorker_12) [homeassistant.components.sensor.scrape]
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<body>
... [redacted] ...
</body>
</html>
2018-08-21 22:17:48 ERROR (MainThread) [homeassistant.components.sensor] scrape: Error on device update!
File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py", line 248, in _async_add_entity
File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 319, in async_device_update
File "/usr/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/usr/lib/python3.6/site-packages/homeassistant/components/sensor/scrape.py", line 120, in update
Update: I am still experiencing the issue on Hass.IO 0.79.2 running on a Raspberry Pi 3.
To make 100% sure this wasn’t an SSL/TLS/Certificate/Trust/Root issue, I found a basic insecure HTTP site to test (http://www.stealmylogin.com). Here’s my config:
and the debug output from the log (I truncated the HTML because it’s long and likely unnecessary):
2018-10-02 19:25:14 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.command_line
2018-10-02 19:25:14 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.scrape
2018-10-02 19:25:14 DEBUG (SyncWorker_9) [homeassistant.components.sensor.rest] Updating from http://www.stealmylogin.com/
2018-10-02 19:25:15 DEBUG (SyncWorker_15) [homeassistant.components.sensor.rest] Updating from http://www.stealmylogin.com/
2018-10-02 19:25:16 DEBUG (SyncWorker_15) [homeassistant.components.sensor.scrape] <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
<html>
<head>
<title>StealMyLogin.com - exposing the dangers of insecure login forms</title>
<style type="text/css">
----- truncated for brevity -----
</script>
</body>
</html>
2018-10-02 19:29:55 ERROR (SyncWorker_14) [homeassistant.components.sensor.scrape] Unable to extract data from HTML
