2018-06-02 23:13:44 WARNING (MainThread) [homeassistant.setup] Setup of config is taking over 10 seconds.
2018-06-02 23:14:17 WARNING (SyncWorker_19) [netdisco.ssdp] Error fetching description at http://192.168.1.5:49155/wps_device.xml
2018-06-02 23:19:34 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.v is taking over 10 seconds
2018-06-02 23:19:34 ERROR (SyncWorker_17) [homeassistant.components.sensor.rest] Error fetching data: <PreparedRequest [GET]>
2018-06-02 23:19:34 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.v fails
File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 204, in async_update_ha_state
yield from self.async_device_update()
File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 327, in async_device_update
yield from self.hass.async_add_job(self.update)
File "/usr/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/usr/lib/python3.6/site-packages/homeassistant/components/sensor/scrape.py", line 115, in update
raw_data = BeautifulSoup(self.rest.data, 'html.parser')
File "/usr/lib/python3.6/site-packages/bs4/__init__.py", line 192, in __init__
elif len(markup) <= 256 and (
TypeError: object of type 'NoneType' has no len()
2018-06-02 23:20:05 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.v is taking over 10 seconds
2018-06-02 23:20:05 ERROR (SyncWorker_13) [homeassistant.components.sensor.rest] Error fetching data: <PreparedRequest [GET]>
2018-06-02 23:20:05 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.v fails
2018-06-02 23:30:27 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from nmap_tracker took longer than the scheduled scan interval 0:00:12
2018-06-02 23:30:53 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from nmap_tracker took longer than the scheduled scan interval 0:00:12
2018-06-02 23:40:09 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
