It displays the XML version. The value I’m looking for is: ns1:value
I’m looking to scrape the height gauge value and import it to an HA entity, so I can know that height of the river. Ideally, I would also be able to use that same entity in a mini-graph card to see the last few days worth of readings in a graph.
Just having a little trouble identifying the data for ingestion. I’m not a developer and have been googling this for months. Any help would be greatly appreciated
You mean gage height I guess and I am not sure what you want to achieve as there are a lot of values. What is the end-result that you have in mind?
Added to that, if you change the rdb at the end in json, then you can consume this data more easily…maybe RESTful or REST sensor but again…what do you need ?
Sorry…I realize now I never explained what I am trying to do. Ideally I would like a card that shows the last height measurement of the river (last entry). I’m assuming I could also use the same entity and have it plot out a mini graph card to show the historical values over the last several days. I also figured out that the URL I posted only shows a static block of time. I was able to tweak the URL to give only last recorded reading. Here is that URL: https://waterservices.usgs.gov/nwis/iv/?sites=01664000¶meterCd=00065&siteStatus=all&format=rdb
