Scraper value_template Trouble
Hey all,
Relatively new to HA, been running HAOS on Raspberry Pi for about a month.
I’ve successfully set up a a webscrapper to retrieve some date from a website, but the front end display of that data isn’t very pretty, see pic below:
Scraper Card
So, I figured the easiest option is to use a value_template to manipulate the string. I came up with the following and checked it in the template option in dev tools:
{% set txt = states('sensor.bin_info') %} {{ txt | regex_replace(find='\\s{2,}',replace='\n', ignorecase=False )}}
Looks good here, but when I use this in the scraper as a value_template the sensor changes from providing the expected day/date and it just returns ‘unknown’:
Where am I going wrong here?
Thanks in advance!
In the value_template you can just refer to the extracted text using the value variable. Your code is a circular reference which can’t work.
  value_template: "{{ value | regex_replace(find='\\s{2,}',replace='\n', ignorecase=False )}}"
Thanks for the quick response!
So using this stops it from returning unknown, but it still doesn’t provide me with the formatting that I see when I use the same code in the template tool.
I’ve also confirmed that this isn’t just a card formatting issue by checking the value of the sensor itself in the state tool.
Maybe the card ignores the newline character? Have tou tried using a HTML break instead? <br/>
I have tried <br/> as well, same result :frowning:
Well, that’s unfortunate. In this case, you might need to look into other cards where you have more control over the layout, like for example the Markdown card.
Spot on - I was trying to avoid manipulating it in the front end, would rather have had the data right at the source but I’ll take it! Thanks
