Gobi
September 30, 2020, 2:32pm
1
Hi, new user of HA here. I’ve started using HA few weeks ago and I’ve been trying to scrape data from my heat pump. Heat pump website login is:
https://www.myupway.com/Welcome
and data is in:
https://www.myupway.com/System/23/Status/ServiceInfo
Can I use normal scraper on or do I need multiscrape to login to that site?
This is what I have at the moment:
- platform: multiscrape
name: home assistant scraper2
resource: https://www.myupway.com/System/23/Status/ServiceInfo
username: -
password: -
selectors:
outsidetemp:
name: Outside temperature
select: '.span.AutoUpdateValue.ID40004'
HTML on the service site:
<span class="AutoUpdateValue ID40004">13.7°C</span>
ra6nar
(Ra6nar)
March 24, 2021, 3:41pm
2
Hi
Do you have had some success with it? I have also myupway and would like to collect some data.
Gobi
March 25, 2021, 4:49am
3
I didn’t get it to work, login was the problem. I couldn’t verify that scraper had logged in.
alboz
September 6, 2021, 1:46pm
4
Any updates with this?
I`m having a same problem, cant get the scraper working with this.
Gobi
September 6, 2021, 6:17pm
5
None, I gave up on scraping data from MyUpway.
arva
(Arva)
September 27, 2022, 8:51am
6
Does anybody have any good idea how to get information from myUpway or directly from the heatpump?
I see that you can add modbus module and then maybe some ESPHome modbus controller to integrate to HA.
Manual of the modbus module: https://www.nibe.no/assets/documents/15716/031725-7.pdf
EDIT: Also some people have had luck to put Nibe firmware to their unit, so you can use Nibe MyUplink API. Unfortunately non Nibe units (Novelan, Metro, Alfa Innotec etc), which are identical hardware uses myUpway which does not have API.
More about it in OpenHab: Nibe uplink binding - #201 by prybil - Bindings - openHAB Community
Thread on Nibe myUplink API: NIBE Uplink API component (non S-series)
Something has been done for no nibe myUPway as well, but it’s only to get data. With Nibe myUplink you can write as well: GitHub - Jalle19/pyupway: Myupway data management scripts
Gobi
September 29, 2022, 12:48pm
7
Hi, I got notification for this thread. I haven’t used HA ever since failing to scrape data from MyUpway, but you could try nibePi, maybe it will work out for you?
# nibepi
Follow this project on Facebook! https://www.facebook.com/groups/nibepi/<br>
<b>Finally a imagefile running Raspberry Pi Bullseye</b><br>
http://anerdins.se/NibePi/nibepi_1.1.1.rar<br><br>
NibePi is an IoT product for your Nibe heatpump
With a Raspberry Pi Zero+RS485 HAT you can communicate with your heatpump by serial protocol. NibePi can fit inside the shell of the heatpump and be powered directly from the terminals.
NibePi supports a lot of Nibe heatpumps, including: Nibe F370,F470,F730,F750,F1145,F1245,F1155,F1255,VVM225,310,320,325,500.SMO20-40<br>
The foundation in this product is built on Node.JS and Node-RED. If the project dosent suit your needs completly it's easy to make your own project with this as a base.
One of the main features in this project is that NibePi is a dependable solution, the filesystem runs in a read-only mode and that makes it almost total secure against corrupt SD-cards. Since no data is written to the SD-card regulary it will not be worn out.<br>
Note that data is written to the SD-card when you change a setting in the user interface. <br>
If you appreciate my work, you can sponsor me with a coffee
https://www.buymeacoffee.com/0oKFXbQ
Hardware used in the project.
This file has been truncated. show original
villeku
(villeku)
November 17, 2022, 1:29pm
8
Hi, I managed to get all needed values from myupway by using multiscraper .
This what I have on configuration
- name: myupway Scraper
resource: https://myupway.com/System/XXXXXXXXXX/Status/ServiceInfo
log_response: false
scan_interval: 60
form_submit:
submit_once: false
resource: https://myupway.com/LogIn
input:
email: !secret myupway_username
password: !secret myupway_password
- unique_id: mlp_outside_temperature
device_class: temperature
unit_of_measurement: °C
select: ".ID40004"
value_template: "{{ value.replace('°C', '') }}"
Please find IDs needed (e.g. ID40004) from myupway web page with browser inspect -function.
<tr role="row">
<td>outside temperature <span class="VariableDesignation">BT1</span></td>
<td><span class="AutoUpdateValue ID40004">-0.8°C</span></td>
</tr>
@villeku This works fine for me also. Thanks!!! I have a Metro Therm Heatpump.
I’m only want to know how to add the sensor degree minutes and how you can fine the right unique_id. Do you know that @villeku
villeku
(villeku)
December 6, 2022, 1:04pm
11
For degree minutes I have yaml configuration like this. You may decide unique_id by yourself but modbus id is important and that can be found from myupway -service
- unique_id: mpl_degree_minutes
name: MLP degree minutes
unit_of_measurement: "DM"
select: ".ID43005"
value_template: "{{ value.replace('DM', '') }}"
A challenge with the multiscrape is - if you want to use device_class - that you must provide a valid device_class with regards to the format of the scraped data.
For the degree minutes you must use device_class: duration. If you use e.g. frequency or timestamp you get an error.
villeku:
DM
Thanks! That works. Any idea how to get defrosting in yaml? It has no device class. Not that I know. The value is Yes or No.
xHuubx
(Huub)
January 27, 2023, 7:30am
15
I use following:
- unique_id: wp_id44703
select: ".ID44703"
RasmusMcNally
(Rasmus Korgaard McNally)
March 10, 2023, 7:56am
16
Hi im New to HA
Can someone explain to me how to get this data into HA.
Im New at this so plain and step by step
Hey guys. Can i get a hand to figuring this one out also
Peer18
(peer18)
November 19, 2023, 4:06pm
18
Hello I’ve copied your code and made an sensors.yaml file. (adjusted to my home)
i’ve pasted the code into the sensors.yaml file but keep getting an error:
"Invalid config for [sensor]: required key not provided @ data[‘platform’]. Got None. (See /config/configuration.yaml, line 11). "
in the config file line 11:
sensor: !include sensors.yaml
sensors.yaml:
> resource: https://myupway.com/System/111111/Status/Serviceinfo
> log_response: false
> scan_interval: 60
> form_submit:
> submit_once: false
> input:
> Sensor:
> - unique_id: mlp_buitentemp
> select: ".ID40004"
I’don’t know how to solve this, can somebody help me please?
kind regards,
Peter
villeku
(villeku)
November 19, 2023, 5:02pm
19
I think you have include multiscrape with different name. For example in configuration.yaml
multiscrape: !include multiscrape.yaml
and multiscrape.yaml contains code above. Hope it helps.
Peer18
(peer18)
November 19, 2023, 6:36pm
20
Thanks, that helped. Also a capitol error Sensor: replaced bij sensor
