jaxzin
(Brian Jackson)
October 29, 2021, 6:34am
1
Seeing that the new Energy dashboard can track the cost of electricity to and from the grid, I realized I wanted to import my energy providers supply and delivery rates as sensors into Home Assistant. Eversource in Connecticut publishes their rates on their website, so I created my first sensors that used the scrape integration to scrape these values from the HTML tables on eversource.com .
Here’s my sensor configuration for other folks in the Northeastern region of the US that also have Eversource as a provider. You’ll need to adjust the URLs for your state.
sensors:
- platform: scrape
resource: https://www.eversource.com/content/ct-c/residential/my-account/billing-payments/about-your-bill/rates-tariffs/electric-supply-rates
name: Eversource Supply Rate
select: "#Main_Main_C005_Col00 .table-responsive tr:nth-child(1) td"
index: 2
value_template: "{{ value | float / 100.0 }}"
unit_of_measurement: "USD/kWh"
- platform: scrape
resource: https://www.eversource.com/content/ct-c/residential/my-account/billing-payments/about-your-bill/rates-tariffs/electric-delivery-rates
name: Eversource Transmission Charge
index: 1
value_template: '{{ value.split("(")[0].split("$")[1] | float }}'
- platform: scrape
name: Eversource Distribution Customer Service Charge
select: "#Main_Main_C005_Col00 .table-responsive tr:nth-child(2) td"
index: 1
unit_of_measurement: "USD/month"
- platform: scrape
name: Eversource Electric System Improvements Charge
select: "#Main_Main_C005_Col00 .table-responsive tr:nth-child(3) td"
index: 1
- platform: scrape
name: Eversource Distribution Charge
select: "#Main_Main_C005_Col00 .table-responsive tr:nth-child(4) td"
index: 1
- platform: scrape
name: Eversource Revenue Adjustment Mechanism
select: "#Main_Main_C005_Col00 .table-responsive tr:nth-child(5) td"
index: 1
- platform: scrape
name: Eversource Competitive Transition Assessment
select: "#Main_Main_C005_Col00 .table-responsive tr:nth-child(6) td"
index: 1
value_template: '{{ value.split("(")[0].split("$")[1] | float * -1.0 }}'
- platform: scrape
name: Eversource Federally Mandated Congestion Charge
select: "#Main_Main_C005_Col00 .table-responsive tr:nth-child(7) td"
index: 1
- platform: scrape
name: Eversource Combined Public Benefits Charge
select: "#Main_Main_C005_Col00 .table-responsive tr:nth-child(8) td"
index: 1
sensors:
eversource_total_rate:
friendly_name: "Eversource Total Rate"
value_template: "{{ states('sensor.eversource_supply_rate') | float + states('sensor.eversource_transmission_charge') | float + states('sensor.eversource_electric_system_improvements_charge') | float + states('sensor.eversource_distribution_charge') | float + states('sensor.eversource_revenue_adjustment_mechanism') | float + states('sensor.eversource_competitive_transition_assessment') | float + states('sensor.eversource_federally_mandated_congestion_charge') | float + states('sensor.eversource_combined_public_benefits_charge') | float }}"
And I added a card to display all these new entities:
This is awesome! Thanks for doing the leg work. Sadly, very little of this translates the rates they charge in NH, where I am. I’m sure each state has different regulations, so it’s hard for them to have a ‘standard’ page that matches state to state.
I’ll see if I can get it all linked up for NH and I’ll post again for anyone else here.
jaxzin
(Brian Jackson)
October 29, 2021, 5:02pm
4
Oops. I shouldn’t have claimed it was just a URL change without looking first! I could take a crack at the CSS selectors for the NH pages if you need assistance.
Just wanted to say thanks so much for these sensors. I got one question. Is it possible to link this up with the energy dashboard so I could see a predicted cost of this month’s energy usage?
jaxzin
(Brian Jackson)
November 7, 2021, 5:11pm
6
Yes, under Configuration > Energy, you can “Use an entity with current price” for both the “Grid consumption” and “Return to grid” settings. Then on the Energy dashboard under “Sources” the “Cost” column should included data going forward. I haven’t found a way to track the cost retroactively.
Awesome. Yea I don’t have my grid meter hooked up yet so that’s probably why I couldn’t figure it out. I don’t need retroactive. I figured everything will be from now and into the future for logging.
Thanks so much for the Eversource scraper again.
JamieC
(Jamie)
December 4, 2021, 9:00pm
8
Thanks for sharing this! Any chance anyone knows how to scrape the information for the supply rate for WMA? I’ve got the other sensors working, but since our rates in western MA are just a change twice a year, there isn’t a table to scrape from. I think I’m close, but can’t seem to get that sensor to populate correctly
ivolodin
(Ilya Volodin)
May 29, 2022, 3:48am
9
Sorry for resurrecting an old topic, but was just doing this for Eastern Mass, and figured I’ll post it here, if anyone will need it:
# Electricity Rates
- platform: scrape
resource: https://www.eversource.com/content/ema-c/residential/my-account/billing-payments/about-your-bill/rates-tariffs/electric-supply-rates
name: Eversource Supply Rate Winter
select: "#Main_Main_C007_Col00 #collapseOne .panel-body>ul:first-of-type>li:nth-of-type(2)"
index: 0
value_template: "{{ value.split('$')[1] | float }}"
scan_interval: 43200
- platform: scrape
name: Eversource Supply Rate Summer
select: "#Main_Main_C007_Col00 #collapseOne .panel-body>ul:first-of-type>li:nth-of-type(1)"
index: 0
- platform: scrape
resource: https://www.eversource.com/content/ema-c/residential/account-billing/manage-bill/about-your-bill/rates-tariffs/electric-delivery-rates
name: Eversource Distribution Energy Charge
select: "#Main_Main_C005_Col00 .table-responsive:first-of-type tr:nth-child(2) td:nth-child(2)"
index: 0
value_template: '{{ value.split(" ")[0].split("$")[1] | float }}'
- platform: scrape
name: Eversource Transition Energy Charge
select: "#Main_Main_C005_Col00 .table-responsive:first-of-type tr:nth-child(3) td:nth-child(2)"
index: 0
value_template: '{{ value.split(" ")[1].split("$")[1] | float * -1 }}'
- platform: scrape
select: "#Main_Main_C005_Col00 .table-responsive:first-of-type tr:nth-child(4) td:nth-child(2)"
index: 0
- platform: scrape
name: Eversource Revenue Decoupling Charge
select: "#Main_Main_C005_Col00 .table-responsive:first-of-type tr:nth-child(5) td:nth-child(2)"
index: 0
- platform: scrape
name: Eversource Distributed Solar Charge
select: "#Main_Main_C005_Col00 .table-responsive:first-of-type tr:nth-child(6) td:nth-child(2)"
index: 0
- platform: scrape
name: Eversource Renewable Energy Charge
select: "#Main_Main_C005_Col00 .table-responsive:first-of-type tr:nth-child(7) td:nth-child(2)"
index: 0
- platform: scrape
name: Eversource Energy Efficiency Charge
select: "#Main_Main_C005_Col00 .table-responsive:first-of-type tr:nth-child(8) td:nth-child(2)"
index: 0
sensors:
value_template: >
{% if now().strftime("%m") | int >= 7 %}
states('sensor.eversource_distributed_solar_charge') | float +
states('sensor.eversource_distribution_energy_charge') | float +
states('sensor.eversource_energy_efficiency_charge') | float +
states('sensor.eversource_renewable_energy_charge') | float +
states('sensor.eversource_revenue_decoupling_charge') | float +
states('sensor.eversource_supply_rate_summer') | float +
states('sensor.eversource_transition_energy_charge') | float +
{% else %}
states('sensor.eversource_supply_rate_winter') | float +
{% endif %}
afp316
September 4, 2022, 5:48am
10
For anyone living in New Hampshire:
# Electricity Rates
- platform: scrape
resource: https://www.eversource.com/content/nh/residential/account-billing/manage-bill/about-your-bill/rates-tariffs/electric-supply-rates
select: "#Main_Main_C005_Col00 > div:nth-child(1) > p:nth-child(4) > strong:nth-child(1)"
index: 0
unit_of_measurement: "¢/kWh"
- platform: scrape
resource: https://www.eversource.com/content/nh/residential/account-billing/manage-bill/about-your-bill/rates-tariffs/electric-delivery-rates
index: 0
value_template: '{{ value.split(" ")[0] | float }}'
- platform: scrape
name: Eversource Regulatory Reconciliation Adjustment
index: 0
- platform: scrape
index: 0
- platform: scrape
name: Eversource Stranded Cost Recovery Charge
index: 0
- platform: scrape
name: Eversource System Benefits Charge
index: 0
sensors:
states('sensor.eversource_regulatory_reconciliation_adjustment') | float +
states('sensor.eversource_stranded_cost_recovery_charge') | float +
states('sensor.eversource_system_benefits_charge') | float }}"
- platform: statistics
entity_id: sensor.eversource_total_rate
state_characteristic: mean
scottg489
(Scott G.)
October 27, 2022, 10:48pm
11
Thanks for this! I was about to use this, but then I noticed that it seems like this information is actually outdated. It seems that this page wasn’t updated mid-year when rates changed.
I compared the figures on that page to my bill and my bill was using different figures. Figures which lined up with this document: https://www.eversource.com/content/docs/default-source/rates-tariffs/ema-cambridge-rates.pdf
Unfortunately PDFs aren’t as easily parsable.
Does this page seem outdated compared to the rates on your bill too?
ivolodin
(Ilya Volodin)
October 28, 2022, 1:07am
12
You are right, it’s a bit off. But it’s close enough, the only charges that seems to differ are distribution and energy efficiency charges. And scraping PDF would be significantly more complicated and not worth it. Your power readings (at least if you are using clamps) are never going to fully match power meter readings anyways. So I think it’s close enough to get an idea of what to expect.
scottg489
(Scott G.)
October 30, 2022, 6:51pm
13
Thanks for confirming. And you’re probably right. What do you mean by clamps, though?
jdiesel
(Jason Diesel)
February 11, 2023, 9:59pm
14
Has anyone ported this to the new Scape Integration yet?
davrod
(David)
February 20, 2023, 9:13pm
15
Looks like there was an update to Eversource’s page. This is mostly greek to me so it took me awhile to figure out how to update the css references. Posting here in case it helps anyone else (or future me)…
- platform: scrape
select: "#MainContentPlaceholder_TEF602CA6001_Col00 .table-responsive tr:nth-child(3) td"
index: 2
- platform: scrape
select: "#MainContentPlaceholder_TEF602CA6001_Col00 .table-responsive tr:nth-child(5) td"
index: 1
- platform: scrape
select: "#MainContentPlaceholder_TEF602CA6001_Col00 .table-responsive tr:nth-child(1) td"
index: 1
- platform: scrape
index: 1
- platform: scrape
select: "#MainContentPlaceholder_TEF602CA6001_Col00 .table-responsive tr:nth-child(2) td"
index: 1
- platform: scrape
select: "#MainContentPlaceholder_TEF602CA6001_Col00 .table-responsive tr:nth-child(4) td"
index: 1
- platform: scrape
select: "#MainContentPlaceholder_TEF602CA6001_Col00 .table-responsive tr:nth-child(7) td"
index: 1
- platform: scrape
select: "#MainContentPlaceholder_TEF602CA6001_Col00 .table-responsive tr:nth-child(8) td"
index: 1
- platform: scrape
select: "#MainContentPlaceholder_TEF602CA6001_Col00 .table-responsive tr:nth-child(6) td"
index: 1
sensors:
davrod
(David)
February 20, 2023, 9:25pm
16
Again, I’ll probably forget this immediately, so for future reference…
I used the browser’s developer tools to find the table entry to the appropriate value, right-clicked and selected Copy selector.
That gave me the following output, where I was able to grab the required reference for the select option on the yaml sensor definition.
#MainContentPlaceholder_TEF602CA6001_Col00 > div:nth-child(4) > div > div > div > table > tbody > tr:nth-child(2) > td:nth-child(2)
JvdMaat
October 12, 2023, 8:15pm
17
Ok, I gotta ask. How did that convert from the Copy Selector to the Select statement for the Scrape integration?
I am using this as my source: Electric Delivery Rates | Eversource (Which for me is WMA).
And I need the 2nd table (Residential Heating).
I can copy your statements, but that gets me all the values from the first table (Residential Non-Heating).
This is my Selector for the first line (Distribution Charge):
#MainContentPlaceholder_TEF602CA6001_Col00 > div:nth-child(6) > div > div:nth-child(8) > div > table > tbody > tr:nth-child(2) > td:nth-child(2)
I tried various combinations, but none give me a result.
dshag86
(Dshag86)
March 26, 2024, 10:15pm
18
I too am trying to figure this one out, did you get it to work?
scottg489
(Scott G.)
November 9, 2024, 12:22am
20
If anyone is interested, utilityapi.com supports Eversource and offers free monthly imports (though rates change even less frequently). I played around with the API a bit and I believe rates are available in there.
heyhewmike
(Heyhewmike)
December 3, 2024, 3:14am
21
I am using multiscrape and I am polling the energizect site for pricing. I already have 2025 pricing updates
- resource: https://energizect.com/rate-board-residential-standard-service-generation-rates
scan_interval: 86400 # 24 hours
- unique_id: eversource_rate1
select: .ssa-component-instance-5d12734d-8646-4877-8994-f920f0fecf91 > div:nth-child(1) > table:nth-child(2) > tbody:nth-child(2) > tr:nth-child(3) > td:nth-child(7)
value_template: "{{ (value | float / 1000) | round(5) }}"
force_update: true
state_class: total
- unique_id: eversource_rate1.3
name: Eversource Rate1 3 Decimal
value_template: "{{ (value | float / 1000) | round(4)}}"
force_update: true
state_class: total
- resource: https://energizect.com/node/7716
scan_interval: 86400 # 24 Hours
- unique_id: eversource_rate_peak
name: Eversource Rate Peak Price
select: .offer-details-dl-right > dd:nth-child(2) > div:nth-child(1)
value_template: '{{ (value.split("¢")[0]) | float / 1000 | round(4) }}'
force_update: true
state_class: total
- unique_id: eversource_rate_fixed_billing
name: Eversouce Rate Fixed Billing
select: div.coh-col-lg-6:nth-child(1) > dl:nth-child(1) > dd:nth-child(4) > div:nth-child(1)
force_update: true
- unique_id: eversource_rate_fixed_until
name: Eversource Rate Fixed Until
select: .incentive-field
force_update: true
- unique_id: eversource_rate_fixed_until_trim
name: Eversource Rate Fixed Until Trimmed
value_template: '{{ (value.split(" ",2)[-1].replace(".", "")) }}'
force_update: true
