Scraping SVG and Embedded zoomable map - anyone done it ? Advice needed
A concrete example may help - what are you trying to actually do?
Thanks - after doing more research, it seems that the scraper will only be returned text values and not necessarily html tags, animations, etc. Just wanted to confirm if its true.
What I would like the result is an interactive svg map to be displayed on Home Assistant. Something like what Webpage card does but i just want to display the map and nothing else. Hope it makes sense
Can you let someone have a URL?
So, no road names or place names? Or just no mosquitto clusters?
Thank you. I just want to display the interactive map as-in so I can do my own zooming and searching. Makes sense ?
Thanks !
hey did you find a solution?
