Hey there.
I failed to read data from my SolarEdge converter + VARTA Pulse Neo solar setup via API and integrations (no solution posted previously here in the forums worked). So I moved on to scraping data from the battery’s local webinterface … but I am overwhelmed. Can someone help me identify which numbers are relevant and worth monitoring? I would then publish them via MQTT and into sensors in HA.
data/common/energyDay_Wh: 22294800
data/common/energyTotal_Wh: 452710800
data/common/power_W: 0
data/pulse/procImg/activePhase: L1
data/pulse/procImg/activePowerAc_W: 0
data/pulse/procImg/apparentPowNormL1_W: 0
data/pulse/procImg/apparentPowNormL2_W: 0
data/pulse/procImg/apparentPowNormL3_W: 0
data/pulse/procImg/apparentPower_VA: 0
data/pulse/procImg/backupMode: False
data/pulse/procImg/counters/countActiveMinutes_m: 8090
data/pulse/procImg/counters/countNrOfSysStarts: 135
data/pulse/procImg/counters/energyCounterAcIn_Ws: 170983260
data/pulse/procImg/counters/energyCounterAcOut_Ws: 139976008
data/pulse/procImg/counters/energyCounterBattIn_Ws: 156224825
data/pulse/procImg/counters/energyCounterBattOut_Ws: 154097029
data/pulse/procImg/counters/energyCounterHouseIn_Ws: 1155876579
data/pulse/procImg/counters/energyCounterHouseOut_Ws: 55285810
data/pulse/procImg/counters/energyCounterPvOut_Ws: 0
data/pulse/procImg/countryCode: 258
data/pulse/procImg/cycles: 8
data/pulse/procImg/emsId: 1
data/pulse/procImg/energyCapacity_Wh: 5867.807000000001
data/pulse/procImg/errorCode: 0
data/pulse/procImg/generatingPower_W: 0
data/pulse/procImg/gridAppPowerL1_W: -2343.384
data/pulse/procImg/gridAppPowerL2_W: -2274.864
data/pulse/procImg/gridAppPowerL3_W: -2357.088
data/pulse/procImg/gridApparentPower_W: 6971
data/pulse/procImg/gridFrequency_Hz: 50.03
data/pulse/procImg/gridPower_W: -6851
data/pulse/procImg/gridReactivePower_W: -1306
data/pulse/procImg/gridSensorPlausible: True
data/pulse/procImg/gridSensorTrustVector: 10
data/pulse/procImg/gridVoltage_V: 228.4
data/pulse/procImg/inverterConnected: False
data/pulse/procImg/isResolvingError: False
data/pulse/procImg/maxChargePower_W: 2496
data/pulse/procImg/maxChrPowImbala_W: 2500
data/pulse/procImg/maxChrPowPlugin_W: 2496
data/pulse/procImg/maxChrPowSOC_W: 2500
data/pulse/procImg/maxDisPowImbala_W: 2500
data/pulse/procImg/maxDisPowPlugin_W: 1557
data/pulse/procImg/maxDisPowSOC_W: 0
data/pulse/procImg/maxDischargePower_W: 0
data/pulse/procImg/nominalChrPow_W: 2500
data/pulse/procImg/nominalDisPow_W: 2500
data/pulse/procImg/nrOfBattUnits: 1
data/pulse/procImg/pExtTarget_W: 0
data/pulse/procImg/pForcedCharge_W: 0
data/pulse/procImg/pTarget_W: 0
data/pulse/procImg/pluginState: 8
data/pulse/procImg/powerDc_W: 0
data/pulse/procImg/preventDeepsleep: False
data/pulse/procImg/preventStandby: False
data/pulse/procImg/psAvgGridPower_W: 0
data/pulse/procImg/reactivePower_VA: 0
data/pulse/procImg/sleepRequested: True
data/pulse/procImg/soc_pct: 0
data/pulse/procImg/soh_pct: 100
data/pulse/procImg/storageState: 8
data/pulse/procImg/temperature1_C: 19.3
data/pulse/procImg/trickleChargeReq: False
data/pulse/procImg/versionEMS: -1.-1.-1
data/pulse/procImg/versionENS: 0.0.0.
data/pulse/procImg/versionInverter: 1.4.2
data/pulse/procImg/vsrcpActivePhase: UNKNOWN
data/pulse/procImg/vsrcpAppPowNormL1_W: 0
data/pulse/procImg/vsrcpAppPowNormL2_W: 0
data/pulse/procImg/vsrcpAppPowNormL3_W: 0
data/pulse/procImg/vsrcpBackupMode: False
data/pulse/procImg/vsrcpConnectionEstablished: False
data/pulse/procImg/vsrcpGeneratedEnergy_Wh: 0
data/pulse/procImg/vsrcpGeneratingPower_W: 0
data/pulse/procImg/vsrcpGridPower_W: 0
data/pulse/batteryType: 7
data/pulse/bmAct/alarmFlags: 0
data/pulse/bmAct/avgCellVoltage_mV: 3451
data/pulse/bmAct/balancingStatus: 0
data/pulse/bmAct/batteryCurrent_dA: 0
data/pulse/bmAct/batteryTemp_dC: 216
data/pulse/bmAct/batteryVoltage_cV: 4830
data/pulse/bmAct/bmsAlarmFlags: 0
data/pulse/bmAct/bmsHwVers: 2
data/pulse/bmAct/bmsSerialNumber: 2207092868
data/pulse/bmAct/bmsSoc_dPct: 20
data/pulse/bmAct/bmsSoh_dPct: 1000
data/pulse/bmAct/bmsStatus: 24608
data/pulse/bmAct/bmsSwVers: 256
data/pulse/bmAct/bmsType: 7
data/pulse/bmAct/bmsWarnings: 0
data/pulse/bmAct/cellVoltage0_mV: 3453
data/pulse/bmAct/cellVoltage10_mV: 3448
data/pulse/bmAct/cellVoltage11_mV: 3451
data/pulse/bmAct/cellVoltage12_mV: 3451
data/pulse/bmAct/cellVoltage13_mV: 3455
data/pulse/bmAct/cellVoltage1_mV: 3449
data/pulse/bmAct/cellVoltage2_mV: 3452
data/pulse/bmAct/cellVoltage3_mV: 3451
data/pulse/bmAct/cellVoltage4_mV: 3451
data/pulse/bmAct/cellVoltage5_mV: 3451
data/pulse/bmAct/cellVoltage6_mV: 3453
data/pulse/bmAct/cellVoltage7_mV: 3449
data/pulse/bmAct/cellVoltage8_mV: 3449
data/pulse/bmAct/cellVoltage9_mV: 3453
data/pulse/bmAct/chargeCurrentLimit_dA: 630
data/pulse/bmAct/dischargeCurrentLimit_dA: 270
data/pulse/bmAct/fault1Flags: 0
data/pulse/bmAct/fault2Flags: 0
data/pulse/bmAct/lifeTimeEnergy_W: 42557
data/pulse/bmAct/maxCellVoltage_mV: 3455
data/pulse/bmAct/maxChargeCurrent_A: 62
data/pulse/bmAct/maxChargePower_W: 3044
data/pulse/bmAct/maxChargeVoltage_dV: 581
data/pulse/bmAct/maxDischargeCurrent_A: 27
data/pulse/bmAct/maxDischargePower_W: 1316
data/pulse/bmAct/minCellVoltage_mV: 3448
data/pulse/bmAct/modCurrent_dA: -1
data/pulse/bmAct/modTemp1_C: 21
data/pulse/bmAct/modTemp2_C: 21
data/pulse/bmAct/modTempAvg_C: 21
data/pulse/bmAct/modUserSoc_dPct: 21
data/pulse/bmAct/modVoltage_dV: 483
data/pulse/bmAct/numOfCycles: 7
data/pulse/bmAct/packSerialNr: 2208276768
data/pulse/bmAct/rackSocMax_dPct: 53
data/pulse/bmAct/rackSocMin_dPct: 48
data/pulse/bmAct/soc_dPct: 50
data/pulse/bmAct/soh_dPct: 1000
data/pulse/bmAct/suddVoltDropStat: 0
data/pulse/bmAct/swVersFull: 16777248
data/pulse/bmAct/warnings: 0
data/pulse/dcDcEnsBmComm/curProtState: 31
data/pulse/dcDcEnsBmComm/lastTimeChanged: 2023-12-12T15:04:22.491
data/pulse/dcDcEnsBmComm/oldProtState: 31
data/pulse/dcDcEnsBmComm/tgtProtState: 31
data/pulse/dcDcEnsBmStatus/checkGridWithExtendedValues: False
data/pulse/dcDcEnsBmStatus/hasResetOccurred: True
data/pulse/dcdcAct/appHwId: 18
data/pulse/dcdcAct/appSerial: 1262687833
data/pulse/dcdcAct/appState: 4
data/pulse/dcdcAct/appVersionMajor: 1
data/pulse/dcdcAct/appVersionMicro: 7
data/pulse/dcdcAct/appVersionMinor: 6
data/pulse/dcdcAct/battState: 2835
data/pulse/dcdcAct/battStateBits/battIsBalancing: 0
data/pulse/dcdcAct/battStateBits/batteryTypeCode: 3
data/pulse/dcdcAct/battStateBits/forceSvdfWaittime: 0
data/pulse/dcdcAct/battStateBits/isValidBatteryTypeCode: 1
data/pulse/dcdcAct/battStateBits/needToStayAwake: 0
data/pulse/dcdcAct/battStateBits/temperatureState: 1
data/pulse/dcdcAct/battStateBits/voltageState: 3
data/pulse/dcdcAct/blVersionMajor: 3
data/pulse/dcdcAct/blVersionMicro: 4
data/pulse/dcdcAct/blVersionMinor: 0
data/pulse/dcdcAct/capacity_Ah: 1133
data/pulse/dcdcAct/chgrState: 0
data/pulse/dcdcAct/dabAngle_pm: -5646
data/pulse/dcdcAct/dischargeCycles: 8
data/pulse/dcdcAct/helperStates: 18627584
data/pulse/dcdcAct/helperStatesBits/bEnableDischargeCtrl: 0
data/pulse/dcdcAct/helperStatesBits/bExpectScomData: 1
data/pulse/dcdcAct/helperStatesBits/battStarted4EmergChrg: 0
data/pulse/dcdcAct/helperStatesBits/batteryCommOk: 1
data/pulse/dcdcAct/helperStatesBits/batteryStartByCli: 0
data/pulse/dcdcAct/helperStatesBits/batteryStarted: 1
data/pulse/dcdcAct/helperStatesBits/batteryStopByApp: 0
data/pulse/dcdcAct/helperStatesBits/batteryStopByCli: 0
data/pulse/dcdcAct/helperStatesBits/diagChargeLock: 0
data/pulse/dcdcAct/helperStatesBits/diagDischargeLock: 0
data/pulse/dcdcAct/helperStatesBits/diagUVccUBattLock: 0
data/pulse/dcdcAct/helperStatesBits/enableUBattChecker: 1
data/pulse/dcdcAct/helperStatesBits/iBattMax: 0
data/pulse/dcdcAct/helperStatesBits/iBattMin: 0
data/pulse/dcdcAct/helperStatesBits/lvrtActive: 0
data/pulse/dcdcAct/helperStatesBits/pwmLockSet: 0
data/pulse/dcdcAct/helperStatesBits/pwmLockState: 0
data/pulse/dcdcAct/helperStatesBits/svIntermCircByCli: 0
data/pulse/dcdcAct/helperStatesBits/swCompatible: 0
data/pulse/dcdcAct/helperStatesBits/temp1Batt1Cold: 0
data/pulse/dcdcAct/helperStatesBits/temp1Batt1Hot: 0
data/pulse/dcdcAct/helperStatesBits/temp2Batt1Cold: 0
data/pulse/dcdcAct/helperStatesBits/temp2Batt1Hot: 0
data/pulse/dcdcAct/helperStatesBits/tempAmbHot: 0
data/pulse/dcdcAct/helperStatesBits/tempBatt1Derate: 0
data/pulse/dcdcAct/helperStatesBits/tempHTHot: 0
data/pulse/dcdcAct/helperStatesBits/tempOptiHot: 0
data/pulse/dcdcAct/helperStatesBits/trickleChargeReq: 1
data/pulse/dcdcAct/helperStatesBits/uBattStartCtrl: 0
data/pulse/dcdcAct/helperStatesBits/uVccCtrl: 1
data/pulse/dcdcAct/helperStatesBits/uVccFromUBattOp: 1
data/pulse/dcdcAct/helperStatesBits/vccFromIntermCircOp: 1
data/pulse/dcdcAct/hwIndex: 4
data/pulse/dcdcAct/iBatt_cA: 0
data/pulse/dcdcAct/iDerate_cA: 1000
data/pulse/dcdcAct/miscStates: 0
data/pulse/dcdcAct/miscStatesBits/battDloadFailFlag: 0
data/pulse/dcdcAct/miscStatesBits/battKillCnt: 0
data/pulse/dcdcAct/miscStatesBits/battKillEmergCharge: 0
data/pulse/dcdcAct/miscStatesBits/battNoCommFlag: 0
data/pulse/dcdcAct/miscStatesBits/battOff4DloadFlag: 0
data/pulse/dcdcAct/miscStatesBits/battOn4DloadFlag: 0
data/pulse/dcdcAct/miscStatesBits/battReady4DloadFlag: 0
data/pulse/dcdcAct/miscStatesBits/derateByTempActive: 0
data/pulse/dcdcAct/miscStatesBits/derateByTempAmbFlag: 0
data/pulse/dcdcAct/miscStatesBits/derateByTempBattFlag: 0
data/pulse/dcdcAct/miscStatesBits/derateByTempHTFlag: 0
data/pulse/dcdcAct/miscStatesBits/derateByTempOptiFlag: 0
data/pulse/dcdcAct/miscStatesBits/derateByTempPassive: 0
data/pulse/dcdcAct/opFlags: 0
data/pulse/dcdcAct/opFlagsBits/autoMode: 0
data/pulse/dcdcAct/opFlagsBits/chargeLock: 0
data/pulse/dcdcAct/opFlagsBits/chargingOp: 0
data/pulse/dcdcAct/opFlagsBits/chrgClearance: 0
data/pulse/dcdcAct/opFlagsBits/chrgCurrent0C1: 0
data/pulse/dcdcAct/opFlagsBits/dischargeLock: 0
data/pulse/dcdcAct/opFlagsBits/dischargingOp: 0
data/pulse/dcdcAct/opFlagsBits/inErrorState: 0
data/pulse/dcdcAct/opFlagsBits/mainSwitch: 0
data/pulse/dcdcAct/opFlagsBits/mainSwitchCli: 0
data/pulse/dcdcAct/opFlagsBits/preChargeOp: 0
data/pulse/dcdcAct/opFlagsBits/startupClearance: 0
data/pulse/dcdcAct/opFlagsBits/swCompatible: 0
data/pulse/dcdcAct/opFlagsBits/tempBattDerate: 0
data/pulse/dcdcAct/opFlagsBits/tempBattFail: 0
data/pulse/dcdcAct/opFlagsBits/voltageSourceOp: 0
data/pulse/dcdcAct/pMaxCharge_W: 2500
data/pulse/dcdcAct/pMaxDischarge_W: 1557
data/pulse/dcdcAct/pNominal_W: 2500
data/pulse/dcdcAct/serial: 4294967295
data/pulse/dcdcAct/socGs_pct: 0
data/pulse/dcdcAct/socHibernate_pct: 29
data/pulse/dcdcAct/socMax_pct: 100
data/pulse/dcdcAct/socMin_pct: 0
data/pulse/dcdcAct/sohChargeMax_pct: 0
data/pulse/dcdcAct/sohChargeSysTime: 0
data/pulse/dcdcAct/sohDischargeMax_pct: 0
data/pulse/dcdcAct/sohDischargeSysTime: 0
data/pulse/dcdcAct/status: 0
data/pulse/dcdcAct/statusBits/chargeState: 0
data/pulse/dcdcAct/statusBits/controlMode: 0
data/pulse/dcdcAct/statusBits/deratingActive: 0
data/pulse/dcdcAct/statusBits/disabled: 0
data/pulse/dcdcAct/statusBits/error: 0
data/pulse/dcdcAct/swIndex: 160
data/pulse/dcdcAct/tempElectronic_C: 25
data/pulse/dcdcAct/tempHT_C: 20
data/pulse/dcdcAct/tempTr_C: 20
data/pulse/dcdcAct/uBatt_cV: 4829
data/pulse/dcdcAct/uIntermCirc_dV: 3103
data/pulse/dcdcAct/uNominal_mV: 5179
data/pulse/dcdcAct/uVcc_cV: 1200
data/pulse/dcdcEnsBmAct/mac: 10717560
data/pulse/dcdcEnsBmAct/netAddress: 0
data/pulse/dcdcEnsBmAct/tmuxId: 22
data/pulse/dcdcEnsBmAct/typeId: 2568714
data/pulse/dcdcEnsBmTgt/mac: 0
data/pulse/dcdcEnsBmTgt/netAddress: 0
data/pulse/dcdcEnsBmTgt/rmuxId: 1
data/pulse/dcdcEnsBmTgt/typeId: 0
data/pulse/dcdcTgt/ctrlFlags: 4
data/pulse/dcdcTgt/ctrlFlagsBits/b7: 0
data/pulse/dcdcTgt/ctrlFlagsBits/chargeDischargeDisable: 0
data/pulse/dcdcTgt/ctrlFlagsBits/enableBatteryStart: 1
data/pulse/dcdcTgt/ctrlFlagsBits/enableVccFromBattery: 0
data/pulse/dcdcTgt/ctrlFlagsBits/enableVccFromIntermCirc: 0
data/pulse/dcdcTgt/ctrlFlagsBits/enterBmDlMode: 0
data/pulse/dcdcTgt/ctrlFlagsBits/enterIdleMode: 0
data/pulse/dcdcTgt/ctrlFlagsBits/enterStandbyMode: 0
data/pulse/dcdcTgt/ctrlFlagsBits/mainSwitch: 0
data/pulse/dcdcTgt/ctrlFlagsBits/resetAck: 0
data/pulse/dcdcTgt/ctrlFlagsBits/resetError: 0
data/pulse/dcdcTgt/ctrlFlagsBits/resetLVRT: 0
data/pulse/dcdcTgt/ctrlFlagsBits/scomDisable4Download: 0
data/pulse/dcdcTgt/ctrlFlagsBits/uIntermCircReady: 0
data/pulse/dcdcTgt/ctrlFlagsBits/uSourceClearance: 0
data/pulse/dcdcTgt/ctrlStateEms: 0
data/pulse/dcdcTgt/ctrlStateInverter: 4
data/pulse/dcdcTgt/tgtPower_W: 0
data/pulse/emeterAct/appVersionMajor: 0
data/pulse/emeterAct/appVersionMicro: 7
data/pulse/emeterAct/appVersionMinor: 3
data/pulse/emeterAct/apparentGrid_VA: 6975
data/pulse/emeterAct/apparentPv_VA: 0
data/pulse/emeterAct/blVersionMajor: 1
data/pulse/emeterAct/blVersionMicro: 6
data/pulse/emeterAct/blVersionMinor: 0
data/pulse/emeterAct/cosPhiGrid_pm: -982
data/pulse/emeterAct/cosPhiPv_pm: 0
data/pulse/emeterAct/errorFlags: 0
data/pulse/emeterAct/errorFlagsBits/b0: 0
data/pulse/emeterAct/errorFlagsBits/b1: 0
data/pulse/emeterAct/errorFlagsBits/b10: 0
data/pulse/emeterAct/errorFlagsBits/b11: 0
data/pulse/emeterAct/errorFlagsBits/b12: 0
data/pulse/emeterAct/errorFlagsBits/b13: 0
data/pulse/emeterAct/errorFlagsBits/b14: 0
data/pulse/emeterAct/errorFlagsBits/b15: 0
data/pulse/emeterAct/errorFlagsBits/b2: 0
data/pulse/emeterAct/errorFlagsBits/b3: 0
data/pulse/emeterAct/errorFlagsBits/b4: 0
data/pulse/emeterAct/errorFlagsBits/b5: 0
data/pulse/emeterAct/errorFlagsBits/b6: 0
data/pulse/emeterAct/errorFlagsBits/b7: 0
data/pulse/emeterAct/errorFlagsBits/b8: 0
data/pulse/emeterAct/errorFlagsBits/b9: 0
data/pulse/emeterAct/fGrid_cHz: 5004
data/pulse/emeterAct/hwIndex: 7
data/pulse/emeterAct/iL1ActiveGrid_cA: -1004
data/pulse/emeterAct/iL1ActivePv_cA: 0
data/pulse/emeterAct/iL1ApparentGrid_cA: -1027
data/pulse/emeterAct/iL1ReactiveGrid_cA: -202
data/pulse/emeterAct/iL1ReactivePv_cA: 0
data/pulse/emeterAct/iL2ActiveGrid_cA: -982
data/pulse/emeterAct/iL2ActivePv_cA: 0
data/pulse/emeterAct/iL2ApparentGrid_cA: -996
data/pulse/emeterAct/iL2ReactiveGrid_cA: -181
data/pulse/emeterAct/iL2ReactivePv_cA: 0
data/pulse/emeterAct/iL3ActiveGrid_cA: -1012
data/pulse/emeterAct/iL3ActivePv_cA: 0
data/pulse/emeterAct/iL3ApparentGrid_cA: -1028
data/pulse/emeterAct/iL3ReactiveGrid_cA: -184
data/pulse/emeterAct/iL3ReactivePv_cA: 0
data/pulse/emeterAct/mac: 836096
data/pulse/emeterAct/netAddress: 31
data/pulse/emeterAct/opFlags: 40
data/pulse/emeterAct/opFlagsBits/activePhaseReflect: 1
data/pulse/emeterAct/opFlagsBits/b10: 0
data/pulse/emeterAct/opFlagsBits/b11: 0
data/pulse/emeterAct/opFlagsBits/b12: 0
data/pulse/emeterAct/opFlagsBits/b13: 0
data/pulse/emeterAct/opFlagsBits/b14: 0
data/pulse/emeterAct/opFlagsBits/b15: 0
data/pulse/emeterAct/opFlagsBits/b7: 0
data/pulse/emeterAct/opFlagsBits/b8: 0
data/pulse/emeterAct/opFlagsBits/b9: 0
data/pulse/emeterAct/opFlagsBits/dataValid: 1
data/pulse/emeterAct/opFlagsBits/iSensorNoSignal: 0
data/pulse/emeterAct/opFlagsBits/reset: 0
data/pulse/emeterAct/opFlagsBits/resetOk: 0
data/pulse/emeterAct/opFlagsBits/swCompatible: 0
data/pulse/emeterAct/pGrid_W: -6850
data/pulse/emeterAct/pPv_W: 0
data/pulse/emeterAct/qGrid_Var: -1303
data/pulse/emeterAct/qPv_Var: 0
data/pulse/emeterAct/serial: 1297367395
data/pulse/emeterAct/swIndex: 168
data/pulse/emeterAct/tmuxId: 2
data/pulse/emeterAct/typeId: 2568970
data/pulse/emeterAct/uAcGrid_dV: 2284
data/pulse/emeterAct/unbalancedLoadGrid_mVA: 0
data/pulse/emeterComm/curProtState: 6
data/pulse/emeterComm/lastTimeChanged: 2023-12-12T15:04:22.492
data/pulse/emeterComm/oldProtState: 6
data/pulse/emeterComm/tgtProtState: 6
data/pulse/emeterTgt/ctrlFlags: 36
data/pulse/emeterTgt/ctrlFlagsBits/activePhase: 1
data/pulse/emeterTgt/ctrlFlagsBits/activePhaseInvalid: 0
data/pulse/emeterTgt/ctrlFlagsBits/b0: 0
data/pulse/emeterTgt/ctrlFlagsBits/b1: 0
data/pulse/emeterTgt/ctrlFlagsBits/b10: 0
data/pulse/emeterTgt/ctrlFlagsBits/b11: 0
data/pulse/emeterTgt/ctrlFlagsBits/b13: 0
data/pulse/emeterTgt/ctrlFlagsBits/b14: 0
data/pulse/emeterTgt/ctrlFlagsBits/b15: 0
data/pulse/emeterTgt/ctrlFlagsBits/b8: 0
data/pulse/emeterTgt/ctrlFlagsBits/b9: 0
data/pulse/emeterTgt/ctrlFlagsBits/disableCanWatch: 0
data/pulse/emeterTgt/ctrlFlagsBits/enableSensorWatch: 1
data/pulse/emeterTgt/ctrlFlagsBits/resetAck: 0
data/pulse/emeterTgt/ctrlFlagsBits/resetError: 0
data/pulse/emeterTgt/ctrlStateEms: 0
data/pulse/emeterTgt/ctrlStateEns: 30
data/pulse/emeterTgt/ctrlStateInverter: 4
data/pulse/emeterTgt/currentSensorCfg: 1
data/pulse/emeterTgt/emsSwIndex: 0
data/pulse/emeterTgt/emsVersionMajor: 0
data/pulse/emeterTgt/emsVersionMicro: 0
data/pulse/emeterTgt/emsVersionMinor: 0
data/pulse/emeterTgt/rmuxId: 1
data/pulse/emeterTgt/timestamp: 1702405534
data/pulse/ensAct/appId: 0
data/pulse/ensAct/ensCtrlOutFlags: 0
data/pulse/ensAct/ensCtrlOutFlagsBits/b10: 0
data/pulse/ensAct/ensCtrlOutFlagsBits/b11: 0
data/pulse/ensAct/ensCtrlOutFlagsBits/b12: 0
data/pulse/ensAct/ensCtrlOutFlagsBits/b13: 0
data/pulse/ensAct/ensCtrlOutFlagsBits/b14: 0
data/pulse/ensAct/ensCtrlOutFlagsBits/b15: 0
data/pulse/ensAct/ensCtrlOutFlagsBits/b4: 0
data/pulse/ensAct/ensCtrlOutFlagsBits/b5: 0
data/pulse/ensAct/ensCtrlOutFlagsBits/b6: 0
data/pulse/ensAct/ensCtrlOutFlagsBits/b7: 0
data/pulse/ensAct/ensCtrlOutFlagsBits/b8: 0
data/pulse/ensAct/ensCtrlOutFlagsBits/b9: 0
data/pulse/ensAct/ensCtrlOutFlagsBits/couplingRelay: 0
data/pulse/ensAct/ensCtrlOutFlagsBits/gridRelay: 0
data/pulse/ensAct/ensCtrlOutFlagsBits/neutralRelay: 0
data/pulse/ensAct/ensCtrlOutFlagsBits/phaseToPhaseRelay: 0
data/pulse/ensAct/ensCtrlState: 30
data/pulse/ensAct/ensErrorFlags: 0
data/pulse/ensAct/ensErrorFlagsBits/b10: 0
data/pulse/ensAct/ensErrorFlagsBits/b11: 0
data/pulse/ensAct/ensErrorFlagsBits/b12: 0
data/pulse/ensAct/ensErrorFlagsBits/b13: 0
data/pulse/ensAct/ensErrorFlagsBits/b14: 0
data/pulse/ensAct/ensErrorFlagsBits/b15: 0
data/pulse/ensAct/ensErrorFlagsBits/b6: 0
data/pulse/ensAct/ensErrorFlagsBits/b7: 0
data/pulse/ensAct/ensErrorFlagsBits/b8: 0
data/pulse/ensAct/ensErrorFlagsBits/b9: 0
data/pulse/ensAct/ensErrorFlagsBits/canTimeout: 0
data/pulse/ensAct/ensErrorFlagsBits/emergencyStop: 0
data/pulse/ensAct/ensErrorFlagsBits/fGridMax: 0
data/pulse/ensAct/ensErrorFlagsBits/fGridMin: 0
data/pulse/ensAct/ensErrorFlagsBits/uGridMax: 0
data/pulse/ensAct/ensErrorFlagsBits/uGridMin: 0
data/pulse/ensAct/ensFGrid_cHz: 5002
data/pulse/ensAct/ensOpFlags: 0
data/pulse/ensAct/ensOpFlagsBits/b10: 0
data/pulse/ensAct/ensOpFlagsBits/b11: 0
data/pulse/ensAct/ensOpFlagsBits/b12: 0
data/pulse/ensAct/ensOpFlagsBits/b13: 0
data/pulse/ensAct/ensOpFlagsBits/b14: 0
data/pulse/ensAct/ensOpFlagsBits/b6: 0
data/pulse/ensAct/ensOpFlagsBits/b7: 0
data/pulse/ensAct/ensOpFlagsBits/b8: 0
data/pulse/ensAct/ensOpFlagsBits/b9: 0
data/pulse/ensAct/ensOpFlagsBits/gridError: 0
data/pulse/ensAct/ensOpFlagsBits/gridOk: 0
data/pulse/ensAct/ensOpFlagsBits/powerOn: 0
data/pulse/ensAct/ensOpFlagsBits/psStatusBatt: 0
data/pulse/ensAct/ensOpFlagsBits/psStatusIntermCirc: 0
data/pulse/ensAct/ensOpFlagsBits/reset: 0
data/pulse/ensAct/ensOpFlagsBits/resetOk: 0
data/pulse/ensAct/ensUGridL1_dV: 2308
data/pulse/ensTgt/ensCtrlFlags: 32768
data/pulse/ensTgt/ensCtrlFlagsBits/disableCanWatch: 0
data/pulse/ensTgt/ensCtrlFlagsBits/disableEns: 0
data/pulse/ensTgt/ensCtrlFlagsBits/emergencyStart: 0
data/pulse/ensTgt/ensCtrlFlagsBits/emergencyStop: 0
data/pulse/ensTgt/ensCtrlFlagsBits/inverterOp: 0
data/pulse/ensTgt/ensCtrlFlagsBits/islandModeEnable: 0
data/pulse/ensTgt/ensCtrlFlagsBits/itCommSignal: 0
data/pulse/ensTgt/ensCtrlFlagsBits/itLocalControl: 0
data/pulse/ensTgt/ensCtrlFlagsBits/relaySetEnable: 0
data/pulse/ensTgt/ensCtrlFlagsBits/reqNaCheck: 0
data/pulse/ensTgt/ensCtrlFlagsBits/resetAck: 0
data/pulse/ensTgt/ensCtrlFlagsBits/resetError: 0
data/pulse/ensTgt/ensCtrlFlagsBits/suspend: 1
data/pulse/ensTgt/ensCtrlOutFlags: 0
data/pulse/ensTgt/ensCtrlOutFlagsBits/b10: 0
data/pulse/ensTgt/ensCtrlOutFlagsBits/b11: 0
data/pulse/ensTgt/ensCtrlOutFlagsBits/b12: 0
data/pulse/ensTgt/ensCtrlOutFlagsBits/b13: 0
data/pulse/ensTgt/ensCtrlOutFlagsBits/b14: 0
data/pulse/ensTgt/ensCtrlOutFlagsBits/b15: 0
data/pulse/ensTgt/ensCtrlOutFlagsBits/b4: 0
data/pulse/ensTgt/ensCtrlOutFlagsBits/b5: 0
data/pulse/ensTgt/ensCtrlOutFlagsBits/b6: 0
data/pulse/ensTgt/ensCtrlOutFlagsBits/b7: 0
data/pulse/ensTgt/ensCtrlOutFlagsBits/b8: 0
data/pulse/ensTgt/ensCtrlOutFlagsBits/b9: 0
data/pulse/ensTgt/ensCtrlOutFlagsBits/couplingRelay: 0
data/pulse/ensTgt/ensCtrlOutFlagsBits/gridRelay: 0
data/pulse/ensTgt/ensCtrlOutFlagsBits/neutralRelay: 0
data/pulse/ensTgt/ensCtrlOutFlagsBits/phaseToPhaseRelay: 0
data/pulse/ensTgt/fGridMaxErrDelayThreshold1_cs: 10
data/pulse/ensTgt/fGridMaxErrDelayThreshold2_cs: 10
data/pulse/ensTgt/fGridMaxOpThreshold1_cHz: 5150
data/pulse/ensTgt/fGridMaxOpThreshold2_cHz: 5150
data/pulse/ensTgt/fGridMaxStart_cHz: 5010
data/pulse/ensTgt/fGridMinErrDelayThreshold1_cs: 40
data/pulse/ensTgt/fGridMinErrDelayThreshold2_cs: 40
data/pulse/ensTgt/fGridMinOpThreshold1_cHz: 4750
data/pulse/ensTgt/fGridMinOpThreshold2_cHz: 4750
data/pulse/ensTgt/fGridMinStart_cHz: 4750
data/pulse/ensTgt/gridCodeCountry: 1
data/pulse/ensTgt/gridCodeId: 1
data/pulse/ensTgt/gridCodeStandard: 2
data/pulse/ensTgt/svdfSocCut_pct: 75
data/pulse/ensTgt/svdfSocThreshold1_pct: 20
data/pulse/ensTgt/svdfSocThreshold2_pct: 5
data/pulse/ensTgt/svdfTime_s: 1860
data/pulse/ensTgt/tGridWatch_s: 60
data/pulse/ensTgt/timestamp: 1702405534
data/pulse/ensTgt/uGridErrDelay_cs: 100
data/pulse/ensTgt/uGridMax10Min_V: 253
data/pulse/ensTgt/uGridMaxErrDelayThreshold1_cs: 0
data/pulse/ensTgt/uGridMaxErrDelayThreshold2_cs: 10
data/pulse/ensTgt/uGridMaxOpThreshold1_V: 288
data/pulse/ensTgt/uGridMaxOpThreshold2_V: 264
data/pulse/ensTgt/uGridMaxStart_V: 253
data/pulse/ensTgt/uGridMinErrDelayThreshold1_cs: 300
data/pulse/ensTgt/uGridMinErrDelayThreshold2_cs: 30
data/pulse/ensTgt/uGridMinOpThreshold1_V: 184
data/pulse/ensTgt/uGridMinOpThreshold2_V: 104
data/pulse/ensTgt/uGridMinStart_V: 196
data/pulse/invAct/appId: 2
data/pulse/invAct/appVersionMajor: 1
data/pulse/invAct/appVersionMicro: 2
data/pulse/invAct/appVersionMinor: 4
data/pulse/invAct/binOutFlags: 0
data/pulse/invAct/binOutFlagsBits/b10: 0
data/pulse/invAct/binOutFlagsBits/b11: 0
data/pulse/invAct/binOutFlagsBits/b12: 0
data/pulse/invAct/binOutFlagsBits/b13: 0
data/pulse/invAct/binOutFlagsBits/b14: 0
data/pulse/invAct/binOutFlagsBits/b15: 0
data/pulse/invAct/binOutFlagsBits/b6: 0
data/pulse/invAct/binOutFlagsBits/b7: 0
data/pulse/invAct/binOutFlagsBits/b8: 0
data/pulse/invAct/binOutFlagsBits/b9: 0
data/pulse/invAct/binOutFlagsBits/couplingRelay: 0
data/pulse/invAct/binOutFlagsBits/firstStartAfterNAError: 0
data/pulse/invAct/binOutFlagsBits/gridRelay: 0
data/pulse/invAct/binOutFlagsBits/neutralRelay: 0
data/pulse/invAct/binOutFlagsBits/phaseToPhaseRelay: 0
data/pulse/invAct/binOutFlagsBits/powerSetPoint: 0
data/pulse/invAct/blVersionMajor: 3
data/pulse/invAct/blVersionMicro: 5
data/pulse/invAct/blVersionMinor: 0
data/pulse/invAct/countryCode: 0
data/pulse/invAct/ctrlState: 4
data/pulse/invAct/errorFlags: 0
data/pulse/invAct/errorFlagsBits/analogChanDefect: 0
data/pulse/invAct/errorFlagsBits/b23: 0
data/pulse/invAct/errorFlagsBits/b30: 0
data/pulse/invAct/errorFlagsBits/b31: 0
data/pulse/invAct/errorFlagsBits/canTimeout: 0
data/pulse/invAct/errorFlagsBits/controllerImplausible: 0
data/pulse/invAct/errorFlagsBits/emergencyStop: 0
data/pulse/invAct/errorFlagsBits/gridCurrentCompAlarm: 0
data/pulse/invAct/errorFlagsBits/iDriftTooHigh: 0
data/pulse/invAct/errorFlagsBits/iRegulatorImplausible: 0
data/pulse/invAct/errorFlagsBits/islandingDetection: 0
data/pulse/invAct/errorFlagsBits/lvrt: 0
data/pulse/invAct/errorFlagsBits/lvrtU: 0
data/pulse/invAct/errorFlagsBits/naFGridTooHigh: 0
data/pulse/invAct/errorFlagsBits/naFGridTooLow: 0
data/pulse/invAct/errorFlagsBits/naUGrid10MinTooHigh: 0
data/pulse/invAct/errorFlagsBits/naUGridTooHigh: 0
data/pulse/invAct/errorFlagsBits/naUGridTooLow: 0
data/pulse/invAct/errorFlagsBits/offsetAdjustment: 0
data/pulse/invAct/errorFlagsBits/operationDoesNotStart: 0
data/pulse/invAct/errorFlagsBits/pwmLockInterrupt: 0
data/pulse/invAct/errorFlagsBits/pwmLockStatic: 0
data/pulse/invAct/errorFlagsBits/pwmLockedByEms: 0
data/pulse/invAct/errorFlagsBits/rcmuDefect: 0
data/pulse/invAct/errorFlagsBits/rcmuDelta: 0
data/pulse/invAct/errorFlagsBits/rcmuHigh: 0
data/pulse/invAct/errorFlagsBits/relayCheckFailed: 0
data/pulse/invAct/errorFlagsBits/tempIgbt: 0
data/pulse/invAct/errorFlagsBits/uIntermCircTooHigh: 0
data/pulse/invAct/errorFlagsBits/uIntermCircTooLow: 0
data/pulse/invAct/errorFlagsBits/voltageUNPEError: 0
data/pulse/invAct/fGrid_cHz: 5002
data/pulse/invAct/fanSpd_dPct: 383
data/pulse/invAct/hwIndex: 4
data/pulse/invAct/iActive_cA: 0
data/pulse/invAct/iApparent_cA: 0
data/pulse/invAct/iDrift_dmA: 0
data/pulse/invAct/iRcmu_mA: 0
data/pulse/invAct/iReactive_cAr: 0
data/pulse/invAct/mac: 5322786
data/pulse/invAct/naFMax_cHz: 514
data/pulse/invAct/naFMin_cHz: 257
data/pulse/invAct/naUMax10min_V: 771
data/pulse/invAct/naUMax_V: 514
data/pulse/invAct/naUMin_V: 257
data/pulse/invAct/naVersionMajor: 1
data/pulse/invAct/naVersionMicro: 2
data/pulse/invAct/naVersionMinor: 1
data/pulse/invAct/netAddress: 30
data/pulse/invAct/opFlags: 6
data/pulse/invAct/opFlagsBits/dcdcResetFrt: 0
data/pulse/invAct/opFlagsBits/exchangedLN: 1
data/pulse/invAct/opFlagsBits/idle: 0
data/pulse/invAct/opFlagsBits/lvrtActive: 0
data/pulse/invAct/opFlagsBits/operation: 0
data/pulse/invAct/opFlagsBits/overload: 0
data/pulse/invAct/opFlagsBits/pUActive: 0
data/pulse/invAct/opFlagsBits/ready: 0
data/pulse/invAct/opFlagsBits/reset: 0
data/pulse/invAct/opFlagsBits/resetOk: 1
data/pulse/invAct/opFlagsBits/selfCheckRunning: 0
data/pulse/invAct/opFlagsBits/temperatureLock: 0
data/pulse/invAct/opFlagsBits/tripZoneWire: 0
data/pulse/invAct/opTimeActive_s: 50528770
data/pulse/invAct/pAvailAcDc_W: 2496
data/pulse/invAct/pAvailDcAc_W: 2496
data/pulse/invAct/pInverter_W: 0
data/pulse/invAct/sInverter_VA: 0
data/pulse/invAct/serial: 1262687829
data/pulse/invAct/statusFlags: 48
data/pulse/invAct/statusFlagsBits/FRedP: 0
data/pulse/invAct/statusFlagsBits/errorGeneral: 0
data/pulse/invAct/statusFlagsBits/errorGrid: 0
data/pulse/invAct/statusFlagsBits/errorIsolator: 0
data/pulse/invAct/statusFlagsBits/errorRcmu: 0
data/pulse/invAct/statusFlagsBits/gridOk: 1
data/pulse/invAct/statusFlagsBits/islandingOverload: 0
data/pulse/invAct/statusFlagsBits/rcmuOk: 1
data/pulse/invAct/statusFlagsBits/selfCheckFail: 0
data/pulse/invAct/statusFlagsBits/selfCheckOk: 0
data/pulse/invAct/statusFlagsBits/swCompatible: 0
data/pulse/invAct/swIndex: 171
data/pulse/invAct/tGridWatchAct_s: 60
data/pulse/invAct/tempAmbient_C: 21
data/pulse/invAct/tempIgbtHb_C: 17
data/pulse/invAct/tmuxId: 0
data/pulse/invAct/typeId: 2568458
data/pulse/invAct/uAcGrid_dV: 2290
data/pulse/invAct/uAcIsland_dV: 389
data/pulse/invAct/uIntermCirc_dV: 3104
data/pulse/invAct/uNPe_dV: 91
data/pulse/invComm/curProtState: 42
data/pulse/invComm/lastTimeChanged: 2023-12-12T15:04:22.685
data/pulse/invComm/oldProtState: 42
data/pulse/invComm/tgtProtState: 40
data/pulse/invStatus/checkGridWithExtendedValues: False
data/pulse/invStatus/hasResetOccurred: True
data/pulse/invTgt/cosMan: 0
data/pulse/invTgt/cosPStartU_W: 241
data/pulse/invTgt/cosPStopU_W: 230
data/pulse/invTgt/ctrlFlags: 32896
data/pulse/invTgt/ctrlFlagsBits/disableCanWatch: 0
data/pulse/invTgt/ctrlFlagsBits/emergencyShutdown: 0
data/pulse/invTgt/ctrlFlagsBits/fanClearance: 0
data/pulse/invTgt/ctrlFlagsBits/itCommSignal: 0
data/pulse/invTgt/ctrlFlagsBits/itLocalControl: 0
data/pulse/invTgt/ctrlFlagsBits/naCheckOk: 1
data/pulse/invTgt/ctrlFlagsBits/naCheckReq: 0
data/pulse/invTgt/ctrlFlagsBits/opClearance: 0
data/pulse/invTgt/ctrlFlagsBits/rcmuEnableDIdt: 0
data/pulse/invTgt/ctrlFlagsBits/reboot: 0
data/pulse/invTgt/ctrlFlagsBits/relaySetEnable: 0
data/pulse/invTgt/ctrlFlagsBits/resetAck: 0
data/pulse/invTgt/ctrlFlagsBits/resetError: 0
data/pulse/invTgt/ctrlFlagsBits/startSelfCheck: 0
data/pulse/invTgt/ctrlFlagsBits/startTestCmdRcmu: 0
data/pulse/invTgt/ctrlFlagsBits/suspend: 1
data/pulse/invTgt/ctrlStateEms: 0
data/pulse/invTgt/ctrlStateEns: 30
data/pulse/invTgt/emsSwIndex: 0
data/pulse/invTgt/emsVersionMajor: 0
data/pulse/invTgt/emsVersionMicro: 0
data/pulse/invTgt/emsVersionMinor: 0
data/pulse/invTgt/fGridMaxErrDelayThreshold1_cs: 10
data/pulse/invTgt/fGridMaxErrDelayThreshold2_cs: 10
data/pulse/invTgt/fGridMaxOpThreshold1_cHz: 5150
data/pulse/invTgt/fGridMaxOpThreshold2_cHz: 5150
data/pulse/invTgt/fGridMaxStart_cHz: 5010
data/pulse/invTgt/fGridMinErrDelayThreshold1_cs: 40
data/pulse/invTgt/fGridMinErrDelayThreshold2_cs: 40
data/pulse/invTgt/fGridMinOpThreshold1_cHz: 4750
data/pulse/invTgt/fGridMinOpThreshold2_cHz: 4750
data/pulse/invTgt/fGridMinStart_cHz: 4750
data/pulse/invTgt/fanCtrl_dPct: 0
data/pulse/invTgt/gridCodeCountry: 1
data/pulse/invTgt/gridCodeId: 1
data/pulse/invTgt/gridCodeStandard: 2
data/pulse/invTgt/oFRedPEnd_cHz: 5150
data/pulse/invTgt/oFRedPOk_cHz: 5020
data/pulse/invTgt/oFRedPS: 5
data/pulse/invTgt/oFRedPStart_cHz: 5020
data/pulse/invTgt/pDcTargetFilter_W: 0
data/pulse/invTgt/pMaxCharge_W: 2500
data/pulse/invTgt/pMaxDischarge_W: 1557
data/pulse/invTgt/pNominalActiveAcDc_W: 2500
data/pulse/invTgt/pNominalActiveDcAc_W: 2300
data/pulse/invTgt/pNominalApparentAcDc_VA: 2500
data/pulse/invTgt/pNominalApparentDcAc_VA: 2500
data/pulse/invTgt/pSetPointTime_s: 0
data/pulse/invTgt/pSetPoint_W: 0
data/pulse/invTgt/pUBorder_V: 258
data/pulse/invTgt/pUFunction: 0
data/pulse/invTgt/pUKink_V: 253
data/pulse/invTgt/pUTime_s: 0
data/pulse/invTgt/qFunction: 0
data/pulse/invTgt/qMan_pct: 0
data/pulse/invTgt/qPMin_pct: 8
data/pulse/invTgt/qPx1_pct: 46
data/pulse/invTgt/qPx2_pct: 92
data/pulse/invTgt/qPx3_pct: 0
data/pulse/invTgt/qPx4_pct: 0
data/pulse/invTgt/qPy1: 0
data/pulse/invTgt/qPy2: 100
data/pulse/invTgt/qPy3: 0
data/pulse/invTgt/qPy4: 0
data/pulse/invTgt/qTime_ms: 10
data/pulse/invTgt/qUDelay_s: 0
data/pulse/invTgt/qUKF: 1
data/pulse/invTgt/qUPStart_pct: 0
data/pulse/invTgt/qUPStop_pct: 0
data/pulse/invTgt/qUx1_V: 218
data/pulse/invTgt/qUx2_V: 225
data/pulse/invTgt/qUx3_V: 239
data/pulse/invTgt/qUx4_V: 246
data/pulse/invTgt/qUy1_pct: -50
data/pulse/invTgt/qUy2_pct: 0
data/pulse/invTgt/qUy3_pct: 0
data/pulse/invTgt/qUy4_pct: 50
data/pulse/invTgt/rmuxId: 7
data/pulse/invTgt/tFRedPOkDelay_s: 600
data/pulse/invTgt/tFRedPStartDelay_ms: 0
data/pulse/invTgt/tGridWatchErr_s: 0
data/pulse/invTgt/tGridWatch_s: 60
data/pulse/invTgt/tIHighErrFRedP_s: 700
data/pulse/invTgt/tIHighErr_ms: 700
data/pulse/invTgt/tIHighOk_ms: 10
data/pulse/invTgt/timestamp: 1702405534
data/pulse/invTgt/uFRedPEnd_cHz: 4000
data/pulse/invTgt/uFRedPOk_cHz: 4980
data/pulse/invTgt/uFRedPS: 2
data/pulse/invTgt/uFRedPStart_cHz: 4980
data/pulse/invTgt/uGridErrDelay_cs: 100
data/pulse/invTgt/uGridMaxErrDelayThreshold1_cs: 0
data/pulse/invTgt/uGridMaxErrDelayThreshold2_cs: 10
data/pulse/invTgt/uGridMaxOp10min_V: 253
data/pulse/invTgt/uGridMaxOpThreshold1_V: 288
data/pulse/invTgt/uGridMaxOpThreshold2_V: 264
data/pulse/invTgt/uGridMaxStart_V: 253
data/pulse/invTgt/uGridMinErrDelayThreshold1_cs: 300
data/pulse/invTgt/uGridMinErrDelayThreshold2_cs: 30
data/pulse/invTgt/uGridMinOpThreshold1_V: 184
data/pulse/invTgt/uGridMinOpThreshold2_V: 104
data/pulse/invTgt/uGridMinStart_V: 196
data/pulse/invTgt/uGridOOk_V: 0
data/pulse/invTgt/uGridUOk_V: 0
data/pulse/invTgt/uIntermCircTgt_V: 350
data/pulse/objectName:
data/pulse/tempEms_dC: 193
getfrechargingstatus/currentTime: 1702401935
getfrechargingstatus/startTime: 0
getfrechargingstatus/stopTime: 0
getfrechargingstatus/surplusCharging: 1
(actually there is even more data but I could not post everything in 1 post – so I left out a few empty values, errorBits and config-related stuff)
