Hi
I want to control the screen brightness from a tablet.
The following service is working, but only to about 30% of the maximum screen brightness.
service: notify.mobile_app_wkrr
message: command_screen_brightness_level
command: 255
Are there any restrictions, that I have to turn off, to reach maximum brightness?
Same result with Fully Kiosk
If I set the brightness on the mobile phone, I see 803% on the light entity
I couldnt find any workaround!
In Fully Kiosk Browser in “Device Management/Screen Brightness”, I can set value 2047 to get 100%.
How can I send this value via HA service - max value there is 255
Make sure you don’t have automatic brightness enabled.
I tried both automatic brightness enabled and disabled.
After changing the brightness to 255 via HA, the result is the same (~30% brightness on the device)
